Author Topic: Cool Tools.  (Read 91131 times)
Re: Cool Tools.
« Reply #450 on: October 21, 2024, 12:17:42 AM »
Saw a place that sold 100, yes 100, 10mm sockets...
Offline spotty
Re: Cool Tools.
« Reply #451 on: October 21, 2024, 12:35:01 AM »
I have one of those rail sets of sockets , all 10mm, 4 of each denomination
i blame Terry
Re: Cool Tools.
« Reply #452 on: October 21, 2024, 06:58:27 AM »
Re: Cool Tools.
« Reply #453 on: October 23, 2024, 03:54:23 PM »
I recycled old weed whacker tank into motorcycle testing tank.  Quick and dirty job using hot glue gun.
Today I learned that gasoline dissolves hot glue  :)
There are two holes in the tank I need to plug somehow.
Re: Cool Tools.
« Reply #454 on: October 23, 2024, 04:06:19 PM »
Try JBWeld “Plastic Repair”. It’s a double sided syringe tube that shoots out equal amounts of epoxy and hardener when you push the plunger. I used it recently and it works!
Re: Cool Tools.
« Reply #455 on: October 23, 2024, 04:58:37 PM »
Polypropylene tanks are known to be impervious to most glues and paints, if made from that, good luck finding something that can work.
Re: Cool Tools.
« Reply #456 on: October 23, 2024, 06:14:35 PM »
I found something like.that in my glue box.  We.shall see if it holds.
BTW the hot glue just disappeared without trace.
Re: Cool Tools.
« Reply #457 on: October 24, 2024, 02:10:09 PM »
This is the stuff I used on the LM650 fender and the cb750K0 airbox. I used the black stuff last time. Just order “translucent” to do more work on the airbox. Cap is brilliant, no mess and no plugging up. Seems to work very well on all plastics. Amazon has it.
Re: Cool Tools.
« Reply #458 on: October 24, 2024, 10:25:01 PM »
Just in case you need a lifetime supply of 10mm sockets...
https://olsatools.com/products/10mm-socket-set
Re: Cool Tools.
« Reply #459 on: October 25, 2024, 03:19:18 AM »
I mix say JB weld metal glue or what ever on an old tupperware lid,it doesent stick to it once hardened,just flex the lid and the unused portion just peels off,needs some special glue to bond to plastics for sure!
Re: Cool Tools.
« Reply #460 on: October 25, 2024, 03:24:11 AM »
Yeah, I do the same; use plastic lid from some recyclable container.  For the auxuiliary tank I used sandpaper to scruff it up and so far so good, it's holding.
Offline richmagee7
Re: Cool Tools.
« Reply #461 on: October 25, 2024, 05:58:38 AM »
That is great, still laughing.  100 sockets, "should last most mechanics a year."
Offline CycleRanger
  • No comment about being an
Re: Cool Tools.
« Reply #462 on: October 25, 2024, 06:31:40 AM »
That is pretty funny. It's always my 10mm wrench I'm misplacing.
Re: Cool Tools.
« Reply #463 on: October 25, 2024, 06:52:44 AM »
Dave; I do the same, usually on a scrap of plastic cut from a windshield washer fluid container. This version of JBWeld does NOT peel off. Something different…..
The ‘69 airbox I’m working on needs lots of repairs. I’ll try the “translucent” next time.
« Last Edit: October 25, 2024, 06:56:10 AM by BenelliSEI »
Re: Cool Tools.
« Reply #464 on: November 05, 2024, 09:43:58 AM »
Picked this up yesterday, couldn’t resist! Note the built in hammer head. Someone stamped their initials “IE” on it and there is a small logo. Large “C” with the letters “H” and “I” inside it. Anyone have any idea on the brand?
Offline Ichiban 4
  • "Ichi"
Re: Cool Tools.
« Reply #465 on: November 05, 2024, 11:26:25 AM »
_____________________________________________________________
Hi!
Don't know about the initials..but the old-timer mechanics I knew years ago used to call those "the original Monkey wrench".
I've always thought them to be that over the years..
Cheers
Ichi/Al
Al Summers
Present: '77 550K
Re: Cool Tools.
« Reply #466 on: November 06, 2024, 04:47:40 PM »
The farmer next door knew the answer. CANADIAN International Harvester. Farm equipment and trucks that were made in Hamilton, Ontario, Canada.
Re: Cool Tools.
« Reply #467 on: November 06, 2024, 10:03:04 PM »
It looks familiar, I might have had one of those tools back in the 70s when we had lots of flee markets around here in southern NH. We had lots of IH tractors around back then.
Re: Cool Tools.
« Reply #468 on: November 08, 2024, 11:19:55 PM »
few years ago a mate rings me up trying to replace rear pads on a rear disc little car,i get there and see its got those wind back pistons,we just fumbled around with pointy pliers and got it done,seeing my wife just got a newer car with rear disc brakes thought Id just buy a cheap "brake cube"you stick a 3/8 drive into it after you select what pattern you need,bit easier if the wind back is stiff,plus i dig weirdo special tools!
« Last Edit: November 08, 2024, 11:21:58 PM by dave500 »
Offline CycleRanger
Re: Cool Tools.
« Reply #469 on: November 09, 2024, 08:32:41 AM »
Interesting. I've never heard of a brake cube. I had to go look up how that's used.
I've never run into screw-in pistons before.
I see it's for the rear brakes with the parking brake.
I guess I've never done a brake job on four wheel disk vehicle before.
Well, now I know! :)
Offline simon#42
  • liverpool
Re: Cool Tools.
« Reply #470 on: November 10, 2024, 02:20:45 AM »
never had any luck with these , you need to push the piston back as you are turning it which is easier said than done .
also if the pads are very worn the cube wont fit in . you would be much better off with a cheap screw type tool , i have just bought a new one for 12 quid . the old one only lasted 30 years and i use it every day !
Re: Cool Tools.
« Reply #471 on: November 11, 2024, 12:06:16 AM »
you remove the old pads to use the cube tool.
Offline simon#42
  • liverpool
Re: Cool Tools.
« Reply #472 on: November 11, 2024, 10:28:00 AM »
yes mate and if the pads were very worn the piston is to far out to fit the tool in .
Re: Cool Tools.
« Reply #473 on: November 11, 2024, 12:56:55 PM »
 I got one of the cubes for the Lincoln disc brakes on my Firebird's 9" Esdel rear end. I've apparently cranked the pistons in while fooling with the E-brake levers.
Re: Cool Tools.
« Reply #474 on: November 12, 2024, 06:34:57 PM »
If the cube can fit in the piston with pads out then couldn't you put a large adjustable wrench on it to screw the piston back in and not use the socket wrench?
