Author Topic: Cool Tools.  (Read 90440 times)
Offline spotty
Re: Cool Tools.
« Reply #600 on: October 03, 2025, 08:44:27 PM »
I'll give it a try anyway, at worst I've got a drill that'll take anything on
i blame Terry
Offline spotty
Re: Cool Tools.
« Reply #601 on: October 03, 2025, 08:46:31 PM »
On special at the local big hardware warehouse $34, about $20 in foreign money.
I've destroyed 3 or 4 of them over the years so another one never goes astray
i blame Terry
Re: Cool Tools.
« Reply #602 on: October 03, 2025, 08:54:57 PM »
It's side loads on an end-mill that'll get you into trouble: if you feed the work in against the direction of rotation, it wants to chatter, and if you feed the work in with the direction of rotation, the end-mill "climbs" into the part, sucking it in, which can cause bad things to happen. ;)
Offline spotty
Re: Cool Tools.
« Reply #603 on: October 03, 2025, 09:18:09 PM »
It appears I'm probably deep in the brown stuff.
Thanks for the heads up
i blame Terry
Offline spotty
Re: Cool Tools.
« Reply #604 on: October 03, 2025, 09:19:48 PM »
Just checked the tool box where they live and I have another 3 new ones but they're all rechargable so a proper full strength one won't go astray
i blame Terry
Offline Mark1976
Re: Cool Tools.
« Reply #605 on: October 04, 2025, 06:22:56 AM »
   I can attest to this, did this very thing years ago, and the drill press is not designed for sideloading, it's a drill "press". Vertical loads yes, everything else no... you may get away with some very light milling of aluminum, but thats it. It's also inherently dangerous when things go wrong, broken metal end-mills being flung around at speed do that.
Start with the end in mind...
Offline spotty
Re: Cool Tools.
« Reply #606 on: October 04, 2025, 11:53:26 PM »
I was at least aware that parts and or vice could become airborne so the vice is securely bolted to the flat deck ( which has a lever that when you release it the deck spins, as does the X/Y vice )
i blame Terry
Re: Cool Tools.
« Reply #607 on: October 08, 2025, 02:30:14 AM »
you can pay nearly 10 bucks for a stupid cardboard circle air filter gasket if you need one,I spied this art and craft kids circle cutter for 5 bucks,yep it works great for grown ups aswell!bottom scale is diameter in metric,upper scale is radius in metric,its brilliantly simple.
« Last Edit: October 08, 2025, 02:36:49 AM by dave500 »
Re: Cool Tools.
« Reply #608 on: October 08, 2025, 06:06:33 AM »
I’m going to have to find one of those for sure! Clever.
Tried a few art, crafts and “dollar” stores and not having much luck Amazon next.
« Last Edit: October 16, 2025, 08:14:07 AM by BenelliSEI »
Re: Cool Tools.
« Reply #609 on: October 10, 2025, 02:17:08 AM »
I have wad punches for most bolt holes,I copied a thermostat housing gasket easy aswell,youd never cut as neat a large hole as this with sissors?these gaskets are $6.95,shop one on the left,my copy on the right.
Offline Honda Hansel
  • Sherwood Park AB
Re: Cool Tools.
« Reply #610 on: October 11, 2025, 02:02:34 PM »
Well I remember back in the old country (Denmark ) we could not bye any gaskets for the old moped (Knallert)
So we had to make gaskets by hand and we could not find the gasket paper .
Every time some one in the house hold got new shoes we sawed the shoe box for gasket material
perfect thickness and it worked just fine,Good old days HaHa
It is a special task to be able to hammer out a new gasket.Ask the younger generation on the knowledge of making a gasket .you will get a look and the head will be tilted to the side and they will reach for the AI info on the phone to see how it's done
Honda Hansel
Honda Hansel
#1 1977 CB750 K7 #2 1981CX500C
#3 1982 CX500TC TURBO #4 2009 KAWASAKI KLX250
#5 2017 YAMAHA 1200 TENERE
#6 2020 KAWASAKI Z900 RS SE
#7 1978 HondaCB750F project bike
#8 1978 Honda CB550K
#9 1968 Kawasaki A1SS 250 cc Two stroke smoker
Re: Cool Tools.
« Reply #611 on: October 11, 2025, 05:50:20 PM »
My favourite for years were corn flakes boxes.
Offline Kelly E
  • Geriatric Hooligan
Re: Cool Tools.
« Reply #612 on: October 11, 2025, 06:39:56 PM »
We always used cold pak beer boxes. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Re: Cool Tools.
« Reply #613 on: October 12, 2025, 12:44:19 AM »
best thing about them is you gotta drink all the beers first!
Re: Cool Tools.
« Reply #614 on: October 16, 2025, 08:16:49 AM »
Found one on Amazon.ca
Offline simon#42
  • liverpool
Re: Cool Tools.
« Reply #615 on: October 16, 2025, 09:08:49 AM »
just ordered one
Offline ratranger
Re: Cool Tools.
« Reply #616 on: October 16, 2025, 07:28:57 PM »
Finally picked up a boring bar, no more searching for shops that can do smaller cylinders for me.
Re: Cool Tools.
« Reply #617 on: October 17, 2025, 01:32:30 AM »
plus you get to use your own precision!
Offline ratranger
Re: Cool Tools.
« Reply #618 on: October 17, 2025, 03:58:22 AM »
I'm going to get used to it with some bad cylinders, that way I'll know if the setting micrometer is accurate and which way I need to compensate to end where I want.
Offline simon#42
  • liverpool
Re: Cool Tools.
« Reply #619 on: October 17, 2025, 10:24:22 AM »
you will need a decent hone to finish the cylinders after they have been bored
Offline ratranger
Re: Cool Tools.
« Reply #620 on: October 17, 2025, 10:50:48 AM »
Yep, I've honed cylinders for waterjet pumps, having worked as a machinist at multiple businesses I have experience doing a ton of different things.   I've got a mill, lathe, vapor blast, parts washer, 20t press and a few other fabrication tools.  Just my mill is old and worn enough I don't trust it to make round bores on cylinders.
Re: Cool Tools.
« Reply #621 on: October 22, 2025, 01:07:38 PM »
Used my new Mity-Vac today. Much improved over my +25 year old one that fell apart a few months ago. Lots of different hose ends, soft hose, and a gauge that measures something! Worked a treat and bled the brakes in minutes. Very Cool Tool!
Well worth having and works on anything.
« Last Edit: October 23, 2025, 06:11:56 AM by BenelliSEI »
Re: Cool Tools.
« Reply #622 on: October 26, 2025, 12:18:54 AM »
I had a cheap air hose powered suction tool for brakes etc toledo copy,I found in my travels as a dumpster truck driver a genuine toledo one,putting the vacuum guage on them shows the toledo one is markedly better vacuum,gave the old one to my neighbour,seeing I have the spray gun out and was servicing my old old old compressor I went the extra mile,and my engine stand and engine hoist,gonna finish em all with rustoleum "sail blue",red oxide primer hides a multiple of sins.
« Last Edit: October 26, 2025, 12:24:21 AM by dave500 »
Re: Cool Tools.
« Reply #623 on: October 26, 2025, 08:20:24 AM »
Which brand/model is that v-twin air compressor pump Dave ?
AUS manufactured ?
Do you have a picture of the Toledo vacuum pump ?
« Last Edit: October 26, 2025, 08:22:56 AM by grcamna2 »
Re: Cool Tools.
« Reply #624 on: October 27, 2025, 12:54:51 AM »
its 1986 aussie made "pro air"Bill with a belt drive vee twin "swan"pump on it,the motor is an aussie "betts"
