Author Topic: Cool Tools.  (Read 90887 times)
Re: Cool Tools.
« Reply #625 on: October 27, 2025, 10:08:04 AM »
its 1986 aussie made "pro air"Bill with a belt drive vee twin "swan"pump on it,the motor is an aussie "betts"
I see.
Do you have a picture of the Toledo vacuum pump Dave ?
Offline Honda Hansel
  • Sherwood Park AB
Re: Cool Tools.
« Reply #626 on: October 27, 2025, 11:36:52 AM »
We always used cold pak beer boxes. 8)
Back in my younger years
The corn flakes came in a plastic bag with all the print on the bag (not a bag in a box)
so we had no choice better then shoe boxes
Beer came in a plastic case and was reused so no gasket's there LOL
Honda Hansel
#1 1977 CB750 K7 #2 1981CX500C
#3 1982 CX500TC TURBO #4 2009 KAWASAKI KLX250
#5 2017 YAMAHA 1200 TENERE
#6 2020 KAWASAKI Z900 RS SE
#7 1978 HondaCB750F project bike
#8 1978 Honda CB550K
#9 1968 Kawasaki A1SS 250 cc Two stroke smoker
Re: Cool Tools.
« Reply #627 on: October 28, 2025, 12:25:53 AM »
ahh sorry Bill,its not a pump per say,you connect it to compressed air pull the trigger and it causes a vacuum at the suction hose,the copy one looked just the same,the toledo seems heavier plastic and does have a markedly better vacuum at the suction hose,ive used it to bleed brakes and change out power steering fluid,its quite fast.
Re: Cool Tools.
« Reply #628 on: October 28, 2025, 08:58:06 AM »
I see  :)
Dave,does it connect to the intake on the air compressor pump,where it sucks air in and through that unit?  or does it somehow have compressed air pass through a type of valve to create a vacuum in it ?
edit: Dave,I read what you said again,and looked at that tube coming out of the plastic tank;I think I got it.
« Last Edit: October 28, 2025, 09:00:22 AM by grcamna2 »
Offline Kelly E
  • Geriatric Hooligan
Re: Cool Tools.
« Reply #629 on: October 28, 2025, 09:44:27 AM »
We have one of those pneumatic brake bleeders. They work great and also work as a vacuum to remove dirty brake fluid from the reservoir instead of pulling it through the system during a flush or getting ready to rebuild and oil pools from heads before you pull them to prevent a big mess. I'm sure there's plenty of other uses as well.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Re: Cool Tools.
« Reply #630 on: October 28, 2025, 01:28:28 PM »
its a kind of siphon system
  • Sherwood Park AB
Re: Cool Tools.
« Reply #631 on: November 02, 2025, 08:30:25 AM »
New creation for the collection
Carburetor stand for ease of rebuilding and wet testing
Took a bit of creative inspirations
Cant wait to do the next set of carbs
Honda Hansel
Re: Cool Tools.
« Reply #632 on: November 02, 2025, 09:24:01 AM »
Nice job on them. I made mine out of 2x4 wood scraps.
Re: Cool Tools.
« Reply #633 on: November 02, 2025, 09:39:40 AM »
Very nice work  :)
Online Don R
Re: Cool Tools.
« Reply #634 on: November 02, 2025, 01:41:38 PM »
 I took some cable ties, cut off the zip part, cut them in half, fold them over, pinch the bend and insert the loose ends into a bolt hole to hold a gasket in place. The part will pop right over them and continue to center the gasket while you start a few bolts.
 In my case it was a front cover and oil pan on a chevy V8 but it should work everywhere.
 film at 11.
Online BenelliSEI
Re: Cool Tools.
« Reply #635 on: November 02, 2025, 02:37:29 PM »
Very nice…. Got me wondering if there was a collector box on the back, with holes matching the carb outlets, could you attach a vacuum and do a vacuum sync. right there on the bench?
Re: Cool Tools.
« Reply #636 on: November 02, 2025, 04:45:14 PM »
 film at 11.
good lord, how have I never learned that?!   I have been making alignment studs by cutting the heads off bolts and cutting a slot for a flatblade...ypur idea is way quicker, easier, cheaper and works just as good!
Online BenelliSEI
Re: Cool Tools.
« Reply #637 on: November 02, 2025, 07:53:19 PM »
 film at 11.
Don….. I tried this today (replacing a gasket on one of the little Z50s) and it’s just brilliant. “Old dog learns new trick”! Thanks!
Online Don R
Re: Cool Tools.
« Reply #638 on: November 02, 2025, 08:14:36 PM »
  It was the counter guy at the parts store that mentioned the zip tie trick when I called to ask if they sold those plastic gasket holder thingies that sometimes come with a gasket. I did have to realize how to use a zip tie to do that.
 There is at least one parts store guy that has actually worked on something.
  • Sherwood Park AB
Re: Cool Tools.
« Reply #639 on: November 03, 2025, 06:53:40 AM »
Hi John
Doing the syncing with a vacuum might work .Bud here is the problem
The engine might not be able to pull the vacuum evenly across the intakes due to variations of the cylinder compression and valve seals (seat seal) so there might be a small problem
How ever lots can be done in the world of creations
Honda Hansel
Online BenelliSEI
Re: Cool Tools.
« Reply #640 on: November 03, 2025, 06:58:38 AM »
Hi John
All good points. I was thinking afterwards that one of the guys I know has a flow bench for testing port flows on heads in modifies. Would be interesting to bolt on a cb750 head, do the carb sync and then see how close it is. Or forget it!
Offline britman
Re: Cool Tools.
« Reply #641 on: November 05, 2025, 12:17:04 PM »
I understand this may be off topic, but I do believe this is a valid tool that was designed and hand formed by a very talented individual.  As some of you know I have recently purchased a 1969 Harley Davidson Servi Car, I am still searching for a valid explanation and if one does come up I will let you know.  This tow bar was securely stored in the box of the bike with angle iron and bed mounted bolts. It was fabricated by the original owner of the machine according to the seller.  It can be removed and assembled in a matter of minutes and mounted to the front axle of Servi and ready to tow in less time.  In the event of a break down what a lifesaver.  I can't imagine trying to get a dead three wheeler in the back of trailer, it is damn heavy and I am very old, I do however have a comfortable pick up with a hitch. I just enjoy seeing good craftsmanship that serves a purpose........
Re: Cool Tools.
« Reply #642 on: November 05, 2025, 08:10:08 PM »
Nice custom tow-bar britman.
Re: Cool Tools.
« Reply #643 on: November 06, 2025, 12:42:24 AM »
you bet!
Re: Cool Tools.
« Reply #644 on: November 06, 2025, 12:22:52 PM »
That Servicar's rear Trunk looks like it would make a good Ice Cream cone type;have a bell  :D
Online Don R
Re: Cool Tools.
« Reply #645 on: November 06, 2025, 02:24:22 PM »
 I'd call that a cool tool.
Online Don R
Re: Cool Tools.
« Reply #646 on: November 17, 2025, 02:45:35 AM »
 Here's my homemade cool tool to press on a harmonic balancer, It's a threaded rod welded to a bolt, a mustang 2 strut washer, and some nuts and bolts and then here's a store-bought kit. The kit includes a bearing that keeps things sliding smoothly.
« Last Edit: November 17, 2025, 02:50:09 AM by Don R »
Online BenelliSEI
Re: Cool Tools.
« Reply #647 on: November 26, 2025, 08:02:39 AM »
Arrived today from OCD Machine in Marion, MT. +US$20 duty, so not too bad!
Can’t wait to try it and retire the old Motion Pro “sticks”……
Re: Cool Tools.
« Reply #648 on: November 26, 2025, 08:51:30 PM »
I just got one o those too!  Came in a batch of parts with a k4 750.
Re: Cool Tools.
« Reply #649 on: November 26, 2025, 10:13:17 PM »
Nice.
I like your timing marks indicator also.
