Author Topic: Frame Weld: Should I be worried?  (Read 975 times)
Offline Jp9090
« on: January 22, 2023, 08:55:08 PM »
Previous owner added some funky welds to the front of this cb500. I'm concerned and no idea whether this bike is safe to ride or not. Any thoughts here anyone is willing to share? Am I screwed?
Offline Jp9090
Re: Frame Weld: Should I be worried?
« Reply #1 on: January 22, 2023, 09:12:28 PM »
Looks to me like they grafted the neck from a bike to a donor back-half. Where’s the VIN tag on the neck??? There should also be an inscribed corresponding and matching number on the opposite side of the neck to assure the tag=VIN.
There's no vin tag on the bike but you can very faintly see the vin engraved onto the neck of the bike just besides the weld on one of the photos.
« Reply #2 on: January 22, 2023, 09:53:05 PM »
I don’t see any developing cracks. But, they could be hidden with paint.  If you are concerned, grind off the paint to expose solid metal with no cracks.  Gonna be a task to see if they maintained original geometry and alignment.  Or, if they just made it sellable.
« Reply #3 on: January 23, 2023, 03:04:04 AM »
I'd be concerned about that also. Definitely you will need to clean it up to see if it's safe or not and check the neck angles.
You are in Sacramento? Does it have current registration and title? No vin tag will be a problem.
« Reply #4 on: January 23, 2023, 03:26:52 AM »
If frame is OK with both wheels aiming into same direction......
Is serial number stamped into that part, "steering head"?
- Will a vehicle inspection accept that?
- It look like a frame fix (identity move), adding an OK serial number on another bike.
If serial number came from a crashed bike in need of a better frame.
Or from a not stolen bike to a stolen one as worst case.
« Last Edit: January 23, 2023, 03:29:24 AM by PeWe »
Offline Shtonecb500
    • Youtube profile
« Reply #5 on: January 23, 2023, 08:05:48 AM »
am i the only one who thinks it looks raked? Those welds look like #$%*. i would strip the paint and look at the welds or grind and re weld...idk.
this come with a title?
Offline Jp9090
« Reply #6 on: January 23, 2023, 08:20:54 AM »
Luckily did come with a title that matches the numbers on the frame.
I think my next steps will be tearing the bike down, stripping paint and looking for cracks on the frame
« Reply #7 on: January 23, 2023, 08:48:20 AM »
Wow..that is ugly!  Wonder if there is some bondo under the paint?
Offline CycleRanger
  • No comment about being an
« Reply #8 on: January 23, 2023, 09:09:00 AM »
I was wondering the same thing.  I would take a wire wheel and remove the paint, just to check it out.
It looks like it could have been brazed rather than welded.
« Last Edit: January 23, 2023, 03:59:49 PM by CycleRanger »
« Reply #9 on: January 23, 2023, 03:55:51 PM »
+3 on checking to see if some bondo was smeared on there also.
Offline WideAWAKE
« Reply #10 on: January 23, 2023, 04:17:45 PM »
This may be a dumb question but you’re just seeing those welds now?
They look aweful.
If it were mine, I’d grind it all back and reweld it.
If you have to ask if those are terrible welds, it’s already established your not capable of fixing them (no disrespect, just the facts)
Take it to a welder and get it cleaned up. Your life depends on it.
The most likely chopped the neck off a bike they had a title to and welded it to one they didn’t.
Replacement vin tags are pretty easy to get online if need be.
Offline jgger
« Reply #11 on: January 23, 2023, 05:11:31 PM »
If there is bondo involved, it looks like the suspect was equally adept at bondo as welding. JMHO.
« Last Edit: January 24, 2023, 04:51:11 AM by jgger »
Offline Shtonecb500
    • Youtube profile
« Reply #12 on: January 23, 2023, 11:31:03 PM »
I just wanted to come back on here and say don't worry, you might be feeling cheated or upset if that wasn't disclosed to you before hand, or that you have more work in front of you, but you'll get through this. You don't need to be worried because you are being responsible and tackling this, rather than ignoring it and riding it and just hoping for the best. Get that paint off and post those pics, I didn't mean to come off so doom and gloom before.
« Reply #13 on: January 24, 2023, 12:17:09 AM »
If frame is OK, let a pro welder make it to look better, like stock. Grind and weld.
« Reply #14 on: January 24, 2023, 12:37:00 AM »
Magnaflux the welds to determine if the welds are sound… just have to strip the frame back to provide enough access for the magnaflux machine. Magnaglow is another trade name for the non destructive testing method. Call around to machine shops to get info and pricing.
Definitely a poorly welded headstock to frame…inadequate equipment or inexperience.
One option would be to buy a clean straight frame and transfer everything over to that titleable frame once you verify it is straight and true… lots of measurements…
« Last Edit: January 24, 2023, 12:45:05 AM by RAFster122s »
« Reply #15 on: January 24, 2023, 12:42:52 AM »
I believe as 500, wake, and others have already indicated..
The posted photographs depict the obvious skill sets excercised…
Offline Jp9090
« Reply #16 on: January 24, 2023, 07:04:57 AM »
Thank you man, I needed to read this. Luckily I have an engine rebuild and clean to get through first but the frame in this condition was starting to get down on me.
I should be able to get some pics with the paint stripped off in the next few days.
Would taking this to a welder for refix be something any welder could do or do I have to look for a specific kind of welder? As many have guessed, no I do not have any welding knowledge!.. yet! Haha taking some classes soon!
Offline Jp9090
« Reply #17 on: January 24, 2023, 07:05:10 AM »
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #18 on: January 24, 2023, 08:57:56 AM »
I was thinking the same thing about the rake.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
Offline Shtonecb500
    • Youtube profile
« Reply #19 on: January 24, 2023, 09:16:52 AM »
In the meantime, take pictures and email them to 3-4 machine shops/welders and see if someone will quote you. Send better pictures than the ones you posted here earlier though.
I'm thinking if you are able to just grind away and re weld it wont cost too much money, but if a welder tells you that you need to chop off the neck and weld it back on, you might be able to find a bare titled frame cheaper than what it would probably cost hourly.
Any welder should be able to the grind and put down some stronger welds, they might refer you to someone more motorcycle specific if the neck needs to be cut off completely....but like i said, in that case, it may be cheaper to find a titled frame and swap everything over.
Me personally, I would junk that #$%*er and find a new frame for 150-200, sounds like you have time during motor rebuild to find one.
Edit: properly disclosed, someone would buy that titled frame from you, like a chopper or rat bike guy.
« Last Edit: January 24, 2023, 12:58:00 PM by Shtonecb500 »
« Reply #20 on: January 24, 2023, 12:17:22 PM »
Would taking this to a welder for refix be something any welder could do...
Depends on what kind of repair is needed.  If just a grind & "touch-up" weld then, yes, most welders should be able to handle that for relatively cheap.
But if the neck needs to be totally welded back on, it may not be feasible to do that as there are specific angles that need to be set.
Get 'er stripped and let us look at it.
Offline Shtonecb500
    • Youtube profile
« Reply #21 on: January 24, 2023, 12:53:58 PM »
am i the only one who thinks it looks raked? Those welds look like #$%*. i would strip the paint and look at the welds orgrind and re weld...idk.
I actually like some rake on bikes,  looks aggressive.
