Author Topic: Throttle Spring Idea  (Read 808 times)
Offline Bigmant
« on: January 24, 2023, 08:26:00 PM »
Hey gang!
I’m at the Mecum Auction this week, and noticed this gem on a CB750 cafe racer they are selling. I played with the throttle and noticed:
1. How easy it was to open the throttle
2. How positively and easily it returned to closed.
This of course prompted me to see how this was done, and the spring setup is what I found. Basically two springs hooked together, and then a string holding the rubber piece that prevents any rubbing. What are your guy’s thoughts? Anyone seen this before?
‘73 CB750 K3 Owned by my father and now me
Build post: http://forums.sohc4.net/index.php/topic,190516.msg2216419.html#msg2216419
Re: Throttle Spring Idea
« Reply #1 on: January 25, 2023, 03:46:47 AM »
I haven't seen that before but might have to try it. Were the 2 springs hooked together under the rubber?
« Reply #2 on: January 25, 2023, 05:41:57 AM »
Looks like if the “string” breaks, no tension?
« Reply #3 on: January 25, 2023, 06:41:35 AM »
Maybe at least use some wire on that bodge.
« Reply #4 on: January 25, 2023, 09:24:14 AM »
That was my thought also. Probably thin stranded stainless steel with a sleeve of heatshrink.
Offline pekingduck
« Reply #5 on: January 25, 2023, 09:29:58 AM »
I'm going to guess that that's a pair of hardware store springs that are shiny, and the big one was too short to reach to the lower plate/hook, and the two of them hooked together were too long.
As stated above, this is a bodge job. A light throttle can be achieved with a single lighter spring of the right size.
Or you can make it even lighter by replacing the string with another, lighter spring.  Or a rubber band. Makes me think what other marvels of engineering are on that bike.
« Reply #6 on: January 25, 2023, 12:50:33 PM »
An even simpler solution on the UK site.
Offline Bigmant
« Reply #7 on: January 25, 2023, 04:22:23 PM »
Like I said, regardless of why this spring is the way it is, the throttle FEELS like a modern throttle. It’s easy to open, and snaps easily and positively shut. I agree about what happens if that string snaps though.
« Reply #8 on: January 25, 2023, 04:34:56 PM »
I’ve done that and it makes a surprisingly big difference!
Offline Bigmant
« Reply #9 on: January 25, 2023, 07:06:06 PM »
Can you guys explain this? I’m not exactly sure what this ring is that I’m looking at.
Offline robvangulik
  • Honda Fourever
« Reply #10 on: January 26, 2023, 03:47:58 AM »
Just a simple washer.
« Reply #11 on: January 26, 2023, 10:21:44 AM »
It is an add on to the existing setup, so if it breaks you should be back to stock feel unless it jams something up...
