Author Topic: 1975 CB750 Points and Timing Adjustment  (Read 903 times)
Offline John G
  • A 1975 CB Rebuild
« on: January 31, 2023, 01:52:22 PM »
Following the book on setting the valve lifters doesn't work because I installed a grind 41 cam which obviously changed the cam lobes enough that I had to rotate the engine for each lifter until the lobe was pointing down to set it. That I figured out. Now if look at the two pictures I've attached you'll notice the notch is pointed on the cam and then with the no. 1 & 4 T and F don't correspond with setting the timing according to the book. Anyone know how I set the timing and points?
John G.
Offline John G
  • A 1975 CB Rebuild
Re: 1975 CB750 Points and Timing Adjustment
« Reply #1 on: January 31, 2023, 02:21:55 PM »
Would an electronic ignition be easier to install?
John G.
Offline robvangulik
  • Honda Fourever
« Reply #2 on: January 31, 2023, 02:37:16 PM »
You should have started with setting the crankshaft on the 1-4 T mark, before timing the camshaft.
Offline John G
  • A 1975 CB Rebuild
« Reply #3 on: January 31, 2023, 04:42:14 PM »
I put No 1 cylinder at TDC. Is that what you mean?
John G.
« Reply #4 on: January 31, 2023, 05:00:30 PM »
If no1 piston is at tdc the T 1-4 mark should be in line with the static mark, as to cam timing the people who ground it should provide instructions!
Offline John G
  • A 1975 CB Rebuild
« Reply #5 on: January 31, 2023, 05:47:17 PM »
I had the no 1 cylinder at TDC and the T lined up as described in the Honda manual. Only problem was I had to rotate the cam to be able to set the tappet. There was no instructions with the cam. I received the cam with the bike when I bought it but there were no timing instructions with it.
John G.
« Reply #6 on: January 31, 2023, 07:50:14 PM »
Most aftermarket cams still time up with the original marks as per diagram then you set the valve clearance, which is frequently different to standard
Offline John G
  • A 1975 CB Rebuild
« Reply #7 on: January 31, 2023, 09:09:16 PM »
Thanks bryanj. I always panic first. Hahaha I still might install an electronic ignition. Time will tell.
John G.
Offline newday777
Stu
My current rides
Prior bikes....
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #9 on: February 01, 2023, 08:23:36 AM »
You will see no difference in the timing advancer T/F pointers whether points or electronic ignition are used. It looks to me more like your cam chain and sprocket are off by one tooth.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline John G
  • A 1975 CB Rebuild
« Reply #10 on: February 01, 2023, 09:28:57 PM »
Thanks Madmtnmotors. I will have a llok at the chain to see if that's my problem. A bit of a head scratcher.
John G.
Offline BenelliSEI
  • 1969 cb750
« Reply #11 on: February 02, 2023, 06:34:10 AM »
+1. That cam needs to go one tooth counter clockwise (when crank set to TDC). Slack off all the adjusters to make it easier.
« Last Edit: February 02, 2023, 08:59:05 AM by BenelliSEI »
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #12 on: February 02, 2023, 06:59:14 AM »
I think I'm dyslexic. When 1-4 are at TDC wouldn't the cam need to come back one tooth, counter clockwise?
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline BenelliSEI
  • 1969 cb750
« Reply #13 on: February 02, 2023, 08:58:11 AM »
No issues for you..... you are correct and I was asleep! Will correct. J.
« Reply #14 on: February 02, 2023, 09:17:11 AM »
Cam/crank alignment should be checked prior to installing the rockers. If the cam/crank alignment is too far off and you are using a high lift/long duration cam you could have encountered valve to piston contact. Of course if turning by hand you would have felt it, but if you try to crank past it (even by hand) you could bend a valve.
TAMTF...
Wilbur
Projects:
Offline John G
  • A 1975 CB Rebuild
« Reply #15 on: February 03, 2023, 01:06:48 PM »
That did it. The chain was a tooth out. Everything now lines up as it should. Thanks everyone.
John G.
Offline Tracksnblades1
« Reply #16 on: February 03, 2023, 05:26:57 PM »
Age Quod Agis
