Author Topic: Rear Lower Engine Bolt  (Read 1147 times)
Offline Ellz10
  • ZZ
  • Knowledge is Power
« on: February 02, 2023, 04:41:47 PM »
I have scoured the interweb and I cannot seem to find the rear lower engine bolt - part # 90155-392-000.
It's for my '77 CB750 K. I understand it's used across many other years.
I'm curious if anyone knows if I'm able to interchange other earlier models K0-K6 with their bolts with threads on both sides or if those are too long/short.
Thankful for everyone on this forum. Grateful to continue to learn so much.
'77 K7 - http://forums.sohc4.net/index.php/topic,193043.msg2251436/topicseen.html#new
Re: Rear Lower Engine Bolt
« Reply #1 on: February 02, 2023, 05:48:10 PM »
Partzilla can be used to figure out the other models where that bolt's part number was used...
You may need to have a machinist make you a new bolt as most bolt houses simply won't make any long enough in that size. Ran into that with a bike I own and the corrosion was enough on the stock bolt to need another. The rod stock was threaded and then a chunk of steel welded to the other end and then cut to the proper hex shape and end dressed.
A good machinist can whip one up in about an hour if he also welds...
You need the specs of the total length, threaded length, length from underside of hex to start of threads. Thread pitch and size of course...
Offline Ellz10
  • ZZ
« Reply #2 on: February 02, 2023, 07:46:19 PM »
Dang. Well I'm hoping that's a last resort and someone has one off a parts bike 🤣
« Reply #3 on: February 03, 2023, 04:21:49 AM »
You could cheat and use threaded bar with a nut at each end, only you will know
Offline newday777
« Reply #4 on: February 03, 2023, 05:21:47 AM »
Threaded rod is pretty soft metal, not much strength to it.
Stu
My current rides
Prior bikes....
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #5 on: February 03, 2023, 07:11:18 AM »
None at Yamiya?
Also, if you look, there is higher grade threaded rod.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #6 on: February 03, 2023, 07:17:47 AM »
I might have one, do you know the dimensions?
Offline MauiK3
  • A K3 is saved
  • Old guy
1973 CB 750 K3
« Reply #8 on: February 03, 2023, 07:51:03 AM »
The -392 in the part number indicates this is a 75/76 CB750F part which could also be used on the 77/78 CB750F. If I was at home, I could check my parts cave for you. Reach out to the F community also.
Offline BenelliSEI
  • 1969 cb750
« Reply #9 on: February 03, 2023, 08:03:30 AM »
I’ve got a box full of them. Post the diameter and grip length (outside frame face to outside frame face) you need and I’ll check. John D.
Offline Ellz10
  • ZZ
« Reply #10 on: February 03, 2023, 10:30:44 AM »
14" long
19mm (3/4") socket head
12mm stock diameter
Thread length is 19mm long
Offline BenelliSEI
  • 1969 cb750
« Reply #11 on: February 03, 2023, 12:02:10 PM »
It’s so darn cold here I might not get to the shop for a couple of days. Dimensions noted, will check.
« Reply #12 on: February 03, 2023, 04:18:20 PM »
14" long
12mm stock diameter
Sorry. I dont have that one.
Offline scunny
  • don't call me expert
« Reply #13 on: February 03, 2023, 04:52:46 PM »
In a pinch, I would use threaded rod, it clamps the motor, not a stress carrier.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline Ellz10
  • ZZ
« Reply #14 on: February 03, 2023, 06:00:21 PM »
Okay, thank you!
14" long
12mm stock diameter
No worries Stev-o! Thanks for looking!
Last resort I'll probably do it this way. But not if I can find the oem bolt.
Offline BenelliSEI
  • 1969 cb750
« Reply #15 on: February 04, 2023, 06:14:05 AM »
I’ll look today.
« Reply #16 on: February 04, 2023, 06:29:57 AM »
I remember one time I was trying to concoct some home brewed rearsets for my 76k.  Somewhere on here, someone posted that you can use an F lower motor mount bolt to help hold rearset mounting plates as it is longer.  So I bought one from an F being parted.  Nope, functionally the same as the 76k.  No idea if I was sent an incorrect part, or if that is just untrue.  It may be possible that all 750 lower mount bolts are functionally the same and Honda changed the part number for some other nebulous reason, perhaps plating type?
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #17 on: February 04, 2023, 06:51:53 AM »
If you run out of options here is some threaded rod. I notice they have a lot of grades including 10.9, high strength.
1973 CB 750 K3
Offline MauiK3
  • A K3 is saved
  • Old guy
1973 CB 750 K3
Offline 69cb750
« Reply #19 on: February 04, 2023, 09:52:46 AM »
I was trying to avoid going into the cold garage to investigate this matter ...
On the 77F there are aluminum brackets which hold the rear foot pegs, brackets look 1" thick, guessing 77F bolt is 2" longer.
Offline BenelliSEI
  • 1969 cb750
« Reply #20 on: February 04, 2023, 10:24:24 AM »
I found one in my bin. 12 mm diameter, both the bolt head and nut take a 19 mm wrench. 14” OA length. Threads are good, but the threaded end has a slight bend.
Easy to straighten with a press or a BFH.
« Reply #21 on: February 04, 2023, 12:20:47 PM »
yeah, but don't forget that on earlier bjkes that bolt holds the chunky footpeg brackets which are at least 3/4"
« Reply #22 on: February 04, 2023, 12:49:35 PM »
I might have one; if I do, I could ship it with the frame kit?
Offline JohnnyL
« Reply #23 on: February 04, 2023, 01:15:31 PM »
I would use grade 8 threaded rod and be done.
My.02
Offline Ellz10
  • ZZ
« Reply #24 on: February 04, 2023, 04:20:07 PM »
Thanks so much for going out to look! The bend on yours is much more minimal than the one on mine! If Scott ends up having one that isn't bent at all, I'll probably just ask him to ship it with the frame kit I'm snagging from him.
On that note: Absolutely Scott - if you do have one and it's not bent at all, I'd be very interested and happy to snag it from you when you send the frame kit. Speaking of which, I never got a reply to the DM I sent ya! Or maybe I did, it just didn't show up. I'll have to go look.
