Yes, notes to self and others…physical inspection of the wiring terminals with magnifying glass or similar sometimes shows you things you miss if you are not careful.
The wire is crimped to the copper and the insulated sleeve of the wire. Usually the wire crimp doesn’t fail, but moisture can cause it to fail.
Fortunately we don’t see a lot of wire rot on the harnesses.
I have seen wiring harness failures on cars caused by moisture, green corrosion, and black wire rot as well.
Heck, Volvo made the mistake in the 80s of a wire supplier who made the wire to breakdown for recycling purposes and the breakdown was too accelerated and after 10 years the insulation was deteriorating and failing. Naturally, it had to get fought in a class action suit to lower the price of replacement harnesses to more reasonably prices as well as reimburse those whom had spent the $1000+ most often they cost. The labor rate was generally 8 hours or more too!
Volvo and the Swedes are big on recycling and it wasn’t malicious intent but movement in direction they were going to have to comply with…
Now Volvo isn’t owned by the Swedes….their engineering took a turn after they went to front wheel drive platforms…not the same longevity and over engineering that was in earlier designs.
