Support the site. Your contributions keep this site running.
Float bowl overflow is from the tube in the float bowls. Fuel is fed via tw “tees” between the carbs (replace the “0” rings), and each carb has a vent pipe from the float bowls (up).
Quote from: BenelliSEI on February 20, 2023, 03:04:33 PMFloat bowl overflow is from the tube in the float bowls. Fuel is fed via tw “tees” between the carbs (replace the “0” rings), and each carb has a vent pipe from the float bowls (up).so the larger fittings are feeds and the two in the very center of the 4 are vents?also should the T's be loose? it has a lot of play, i assume there are seals that have probably gone bad?
They will rotate up and down while mounted between the carbs with some resistance. Each side of the tee has 2 o-rings so 4 per tee and 2 tee's make for a total of 8. Do you have a Clymers or other type of manual yet ?
