Author Topic: Good Tape  (Read 2382 times)
Offline DaveBarbier
Re: Good Tape
« Reply #25 on: February 27, 2023, 01:11:33 PM »
Tessa wire harness tape is good stuff. It’s more of a fabric type tape.
Offline grcamna2
Re: Good Tape
« Reply #26 on: February 27, 2023, 02:10:53 PM »
There is a stretchy tape that sells at most hardware stores here. It does not have adhesive on the back. You pull it tight (stretching it a bit) and it clinches down on itself. It’s suppose to be for emergency repairs to domestic drains and waterlines. I’ve used it for repairing looms (short repairs) with success. It’s easy to have a tight start, but the end is tough to get to stay put. Last time I used a dab of contact cement and wrapped a zip tie around it, overnight. Still looks great!
P.S. not sure what the stuff is called, and not cheap. Maybe some one else will pipe in.
Hi John,could you find out what they call that stretchy tape you've described ?
75' CB400F/'bunch o' parts'
Offline dusterdude
Re: Good Tape
« Reply #27 on: February 27, 2023, 02:35:24 PM »
My favorite tape is Santana Abraxis on 8 track, but the 3m super 88 is good.
Hell yea brother
Sent from my SM-G973U1 using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Airborne 82nd
Re: Good Tape
« Reply #28 on: February 27, 2023, 02:41:53 PM »
Insulating Electrical Tape: Self-Fusing High-Volt, 3M™, Scotch®, 23, Rubber, 3/4 in x 30 ft, 30 mil Tape Thick
In high voltage apps. it used over the top of of plastic tape but works good by its self. I have used it for years up to 4180vac no sticky glue.
« Last Edit: February 27, 2023, 03:02:12 PM by Airborne 82nd »
Offline Tracksnblades1
Re: Good Tape
« Reply #29 on: February 27, 2023, 03:05:07 PM »
Is that Aviation tape.  The really good stuff….
Age Quod Agis
Re: Good Tape
« Reply #30 on: February 27, 2023, 03:15:07 PM »
Had to smile when I read 4180volts…..They called the same here 4160…but it always measured 4180 low load..
It’s good to know someone else was under the NEC’s thumb…
While we’re not talking weather/waterproof splices and lugs here, it’s good to know what tapes are reserved for it..
Age Quod Agis
Offline grcamna2
Re: Good Tape
« Reply #31 on: February 27, 2023, 03:49:32 PM »
I appreciate it  ;)
Re: Good Tape
« Reply #32 on: February 28, 2023, 10:01:44 AM »
Only 1 type of tape is not enough after reading this thread! ;D
Offline grcamna2
Re: Good Tape
« Reply #33 on: February 28, 2023, 10:16:56 AM »
+1   ;)
Re: Good Tape
« Reply #34 on: February 28, 2023, 03:13:11 PM »
I prefer Highlander...
There can only be one!
Re: Good Tape
« Reply #35 on: March 01, 2023, 01:13:36 PM »
Duncan Macleod. From the Clan Macleod…..😁
Age Quod Agis
Offline BenelliSEI
  • 1969 cb750
Re: Good Tape
« Reply #36 on: March 11, 2023, 12:46:13 PM »
Sorry..... I missed this! We’re off for an extended trip, so may be a while. One of the responses here seemed correct. It is in the automotive section of my local Canadian Tire Store, and the photo on the package shows it wrapped snuggly around a rad split rad hose.
Last year, when we took the LEXUS to the first race, we discovered the fill pipe to the fuel tank had completely hardened and cracked all over. We carefully removed this long, moulded hose and wrapped it end to end with this stretchy tape. Probably used three rolls. It did get a bit “gooey”, but held for a few more weekends, before we installed a fuel cell with all new hoses. Good stuff to have around for an emergency.
« Last Edit: March 11, 2023, 12:47:52 PM by BenelliSEI »
Re: Good Tape
« Reply #37 on: March 15, 2023, 02:00:54 PM »
 I just used some of this, I had forgotten it was in the bike stuff drawer of the tool box ,I like it. Thin and less adhesive.
http://vintageconnections.com/Products/Detail/184
Offline grcamna2
Re: Good Tape
« Reply #38 on: March 15, 2023, 03:20:08 PM »
Don,how do you like using it to repair an OEM Honda harness:will it be compatible to match the original factory Honda non-adhesive stretch tape. Will it hold-up for a couple years w/o unraveling ?   thanks,Bill  :)
Re: Good Tape
« Reply #39 on: March 15, 2023, 03:28:11 PM »
 I just used it for the first time yesterday. It was on the hot rod bike so I wasn't paying attention to the texture and color but I believe it was close to the Honda oem tape. It wrapped on easily and curled around a branch just like the Honda tape did.
 Vintage connections also has a wiring bundle sheath tube that is close to oem.
Offline grcamna2
Re: Good Tape
« Reply #40 on: March 15, 2023, 03:58:14 PM »
Yes,I just looked at their site and noticed the 14mm black gloss PVC tube for the wiring harness;it seems they are now owned by Spark Moto.
