Author Topic: Has anyone used the Alpha Moto carb sync gauge tool?  (Read 4329 times)
Re: Has anyone used the Alpha Moto carb sync gauge tool?
« Reply #1 on: February 26, 2023, 04:20:58 PM »
Those look good. I use an ancient Motion Pro 4 X glass stick unit. They work great but the liquid in them evaporates (and I occasionally suck it away) so they need cleaning, refilling and occasionally ā€œ0ā€ ring replaced. Something fully electronic might be less hassle?
« Reply #2 on: February 27, 2023, 12:27:14 AM »
Price makes me suspect the gauges are not top quality but you can check them against each other and compensate
Offline denward17
« Reply #3 on: February 27, 2023, 08:02:00 AM »
I ordered the CarbTune Pro 4.
Hopefully it will work good when I need it.
Offline Ujeni
« Reply #4 on: February 27, 2023, 09:15:37 AM »
Ive used dial gauges like these for many years. Assuming they are calibrated, they will work well.
A few months ago I bought the CarbTune Pro 4 and it certainly feels just as nice if not better!
Ujeni Motors
Sandcast #410
Sandcast #538 Watch the restoration!
Sandcast #6592 All original daily driver.
« Reply #5 on: February 27, 2023, 11:37:04 AM »
Will be interested how they perform. Iā€™m due an upgrade.
Offline craz1
  • CDA, Idaho
« Reply #6 on: February 28, 2023, 07:40:04 PM »
I like my homemade mercury gages but if I needed a set I would be interested in these. Little on the expensive end of the scale
https://thedigisync.com
74 CB550,73 Z1900, 74 Z1900, 75 Z1900,
72 XS2650, 73 RD350, 2013 FJR1300, 84 XJ550 YAM
Offline Maltboy
  • Pitter-patter, let's git at 'er!
  • Making stupid mistakes since 1959
« Reply #7 on: March 01, 2023, 06:34:45 PM »
The CarbTune is a quality product. I think you'll be happy with it.
Offline Kelly E
  • Geriatric Hooligan
« Reply #8 on: March 02, 2023, 08:16:32 AM »
We had a DigiSync but sold it. It's way too hard to use because of the constantly changing numbers. The mercury type or gauge type are much easier to read.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #9 on: March 03, 2023, 03:18:03 AM »
I know what you mean. An exhaust gas analyzer is another example. The changing numbers drive you crazy. Analogue is way easier. You can monitor the dial from the corner of your eye and see the tendency.
Monitoring RPM during tune-up. Use an analogue meter with preferably a scale that has 20 rpm increments.
To monitor the voltage drop during an electric start to check the battery's condition, use an analogue volt meter.
Monitoring voltage dynamically from idle to revved, use an analogue volt meter.
Offline Johnie
« Reply #10 on: March 03, 2023, 08:11:24 AM »
I've used my Morgan Carb Tune for 20 years now and still works great. No fluttering of the slides. Bikes run smooth. Very happy with it.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #11 on: March 03, 2023, 04:41:05 PM »
[/quo
I like the look of that. A lot like my old Motion Pro. Are the slides liquid or solid? Thanks!
Online newday777
« Reply #12 on: March 03, 2023, 06:41:31 PM »
[/quo
They are solid bars
« Reply #13 on: March 04, 2023, 01:31:48 AM »
CarbTune Pro 4 work fine. Easy to see all beside eachother.
Double check that you connect to right carb before adjustments.
Easy to reverse order when standing at the cyl 4 side.
You'll see that carbs affect eachother when adjusting.
One carb might be opened more than the other which will increase engine speed and the other carbs underpressure.
I have often seen that #4 is wrong, adjusting #3 helps more than adjusting 4 and vice versa.
This on my Mikuni TMR
« Last Edit: March 05, 2023, 03:40:33 AM by PeWe »
Offline bacongrease
« Reply #14 on: March 10, 2023, 05:52:55 PM »
 geez..I see quite a large number of available manometers. Sense I am in the market:
 I am still patiently awaiting recommendations from the peanut gallery for some of the lower priced ones.
« Last Edit: March 10, 2023, 06:11:27 PM by bacongrease »
« Reply #15 on: March 11, 2023, 02:15:06 AM »
It's a bit difficult for me to advise, because it's decades ago I've used my set. I donated it actually to a friend. I've developed my own - no noise - method. The Morgan thing could be a good choice, but I have no experience with it. For instance, I don't know if it reacts the same as the conventional manometers. By that I mean the pace: indicating underpressure is one thing, but also the pace in which the underpressure changes (comes down after a blip) can provide useful information like a too lean setting. I don't know if the Morgan thing is doing this in the same way as conventional manometers. Others may know.
For those of you interested in where to initially set the adjuster screws of the oldstyle CB500/550 carbs, as a startingpoint for after they have been apart, I can share some advice. But, alert: these carbs do not need to be separated from the rack ever. Only when the O-rings at the T-joints would be shot, which is not likely to happen. Honda fit two on each side! Mine are still the originals (1976). One spring they leaked a bit, after hibernation prior to which I had drained the carbs dry for a change. Never did this before and I will not do it again. Luckily at that occasion those 8 O-rings have swollen back to their original size. Conclusion: if you leave your carbs in a natural state, which is wet and don't feed any aggressive fluids down the lines, they'll live forever.
Offline rotortiller
« Reply #16 on: March 11, 2023, 08:20:00 AM »
It's not so much the tool as it is the person using it.
« Reply #17 on: March 11, 2023, 12:24:30 PM »
My Motion Pro is a basic unit and I really like it. Buy a new one, and read the instructions carefully. Synchronization of the four chambers, on every use, only takes a minute, but is important. On occasion (usually when someone borrows it), all the blue liquid disappears. It happens when you blip the throttle and close it too quickly. Order an extra bottle of the liquid, day one.
« Reply #18 on: March 11, 2023, 01:22:29 PM »
I too have the Motion Pro set-up, and lol, you must be right  Because I have never had to replace he fluid, and also have never loaned it out.  Having used the Morgan Carbtune, it is much solider, quicker, and easier to use...wish I would have bought it instead.
« Reply #19 on: March 13, 2023, 08:44:11 AM »
I like my old school Honda gauges...
Offline Magpie
« Reply #20 on: March 13, 2023, 09:56:26 AM »
rotortiller said "It's not so much the tool as it is the person using it." Too true.
I prefer the old school way of vacuum gauges over the Carbtune. The gauges seem to give me more feedback, I don't how to describe it, more emotional? The Carbtunes were not as helpful.
Like vinyl vs. digital.
« Reply #21 on: March 13, 2023, 11:14:07 AM »
You will hear when the sync tool show right values.
Do not forget to slowly increase throttle to at least +3000 rpm to see  and hear all carbs stay in sync.
Slowly decrease should be equal too. Very irritating to ride a bike that are not in sync when slowly increase or roll-off.
A few snappy throttlings too ;)
Offline Johnie
« Reply #22 on: March 13, 2023, 02:40:33 PM »
And just to be sure put a nice fan on the motor during sync so you don't overheat.
Oshkosh, WI  USA
Offline Erny
« Reply #23 on: March 13, 2023, 03:41:07 PM »
I will add to this topic my recent finding.
There is interesting tool available (HealTech eSync), having function of carbs sync but also (they claim) you can identify issues with valves  :o https://www.healtech-electronics.com/products/est/
Clear disadvantage is need of notebook, but many of us have it anyway in garage at hand (I do)
Have a look at video (install and test video section)
Did not use it, want to test first if I have opportunity.
It is made in Hungary, Europe, not cheap China stuff...
No doubt I'm fan of old-school tools (as already mentioned RPM meter, voltmeter etc), but sometime modern tool is good too  ;)
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Offline dugsgms
« Reply #24 on: March 13, 2023, 04:01:30 PM »
 If you don't mind a bit of work here a set up I made using basic stuff from home depot and some vacuum fittings from the auto parts store. Works well but works even better when the tubes are restricted with some old pilot jets to buffer the readings. First 2 pics show the construction and the last 2 in use(before and after adjustment.
1970 BSA Lightning
1975 Yamaha RD350
1975 Honda CB400f
2008 Yamaha WR250R
