Author Topic: 71 CB500 - this will be work  (Read 12479 times)
Offline cheddarGoblin
Re: 71 CB500 - this will be work
« Reply #75 on: October 29, 2024, 04:03:04 AM »
Now would be a great time to grease that swingarm pivot bushing too. Bet you’ll find it needs some deep love too.
I've realized I need to check the swingarms on all my bikes. I did check this one though before I took the wheel off, and did not notice any play, so hopefully all it needs is grease.
It seemed like a good idea at the time
1975 CB200T
1982 Nighthawk 650
1981 GL500
1971 CB500
1972 CL350
Offline Oddjob
« Reply #76 on: October 29, 2024, 04:24:17 AM »
Is the ball bearing still inside the clutch adjuster?
« Reply #77 on: October 29, 2024, 04:30:04 AM »
That sprocket is toast...
OEM bearing retainers are NLA from Honda but aftermarket are available. There is a good bearing retainer wrench DSS carries and is also sold on away that makes that retainer much easier to remove after you drill the staked holes. Gonna need either a bench with dogs to clamp wheel down or someone else to hold it to get the needed leverage. It is a bear to remove by yourself.
The wrench has a machined cylinder with properly spaced pins to engage the holes in the retainer with a long arm to the wrench to give you the leverage. Once you get it started moving it becomes much easier. If you don't drill the stakes over threads the retainer is likely to wreck the threads on the hub.
Nico abrasives makes a synthetic string wheel that can clean up and even remove some of the rubbing in the hub. The ribbing area in the center of the casting is very coarse and tough to get clean. ScotchBrite pads can clean up the rest of the hub if you aren't planning to polish it, lots of tricky areas to sand and polish if you are looking to make it very shiny...
Offline Oddjob
« Reply #78 on: October 29, 2024, 04:46:04 AM »
That's not a 500 rear wheel. The studs don't come out like that, possibly 400/4?
« Reply #79 on: October 29, 2024, 06:07:55 PM »
Yep it is there. Everything seemed to operate pretty smoothly once reassembled.
1975 CB200T
1982 Nighthawk 650
1981 GL500
1971 CB500
1972 CL350
« Reply #80 on: October 29, 2024, 06:13:45 PM »
Wow! It seems you are right, good eye!
I checked the parts fiche and it looks like it is from a CB450.
Now I am not sure if I should continue rebuilding it or look for a correct wheel. I had already gotten it complete disassembled before seeing your post.
1975 CB200T
1982 Nighthawk 650
1981 GL500
1971 CB500
1972 CL350
« Reply #81 on: October 30, 2024, 12:59:17 AM »
I might have a spare 500 hub that would be completely usable. Oddly enough, I probably live less than 20’ from you.
I just had a peek in the parts cave, and sure enough I have a rear hub in perfect condition with new bearings and plush cush rubbers. You’ll just need to lace it to a rim. Send me a PM if you’d like it.
Excellent 'save'  ;)
« Reply #82 on: October 30, 2024, 03:06:34 AM »
Awesome! Will do!
1975 CB200T
1982 Nighthawk 650
1981 GL500
1971 CB500
1972 CL350
« Reply #83 on: October 30, 2024, 03:22:57 AM »
I completed the below right before checking this thread and finding out the wheel was from a different bike. :)
I've had this tool for years, I think it was to disassemble a hub from a Nissan that I no longer own. I was able to modify it to fit into the holes of the bearing retainer. The "pins" were very thin but with some heat and PB Blaster, the bearing retainer came out.
Not sure how this bearing spacer could have gotten this bent up.
Just a reference for wheel condition and to make sure I get it laced properly.
Zip, zip
And. it's apart.
1975 CB200T
1982 Nighthawk 650
1981 GL500
1971 CB500
1972 CL350
« Reply #84 on: November 10, 2024, 04:50:54 AM »
I have to give a HUGE thank you to CalJ737 for getting me setup with the proper hub. He not only generously provided it but even delivered it! I will be making a donation to the site at per his suggestion but first I have to find my checkbook :)
Not only did he provide the proper hub, it's even clean and ready to go, (and ceramic coated I think?) saving me a ton of time as well cleaning the wrong one.
I wasn't sure if the brake would fit properly or I would need something else but so far I haven't found anything else I need for reassembly.
The rim was in rough shape. Electrolysis is my new favorite method of rust removal. It still took a couple baths and some wire wheel work to get it ready but eventually got all the rust removed. Once I got it clean, I put a thin layer of clearcoat on it.
I got it loosely laced. Ready to install the bearings (that even came with the hub!) and true it up. The hub was so nice I had reservations about using the existing rim as it still had some gouges and pits that weren't going anywhere. But the bike is going to have patina anyway, so had to move forward.
Thanks again Cal!
1975 CB200T
1982 Nighthawk 650
1981 GL500
1971 CB500
1972 CL350
Online newday777
« Reply #85 on: November 10, 2024, 06:09:24 AM »
Progress is always a good feeling
« Reply #86 on: November 10, 2024, 11:49:01 AM »
Congrats on the progress and good on you Calj
« Reply #87 on: November 12, 2024, 07:16:55 AM »
I have to give a HUGE thank you to CalJ737 for getting me setup...
I dont care what anyone says, Cal is a great guy!!  Ha
« Reply #88 on: November 24, 2024, 11:52:31 AM »
I think I am getting the hand of wheel truing. It isn't very fun but it is something that I am glad I learned how to do.
1975 CB200T
1982 Nighthawk 650
1981 GL500
1971 CB500
1972 CL350
Offline denward17
« Reply #89 on: November 24, 2024, 12:11:02 PM »
Looks better than factory, great job!
« Reply #90 on: November 24, 2024, 12:44:56 PM »
Now to do something about this. Going to clean it up, give it a polish and install new brake shoes.
The cleaning and polishing went fine, ran into a bit of an issue installing the new braks shoes though.
I ordered shoes from 4 into 1, which I have never had an issue with until now. The shoes did not fit properly on either end because the material was too thick. It did not fit into the cam and blocked the hole for the cotter pin when set onto the pivot pin. It also did not have any sort of chamfer on the pivot pin side.
Comparing the old shoe (left) with the new. This is the cam side.
Every other dimension seemed to match so other than maybe 1/16" difference, they seemed correct. I didn't really want to but decided to just make them fit...
I just cut a slight notch into the end with a dremel and then ground it until I hit the mark, then flattened it with a file. Yeah, the aluminum clogged everything up but it
I did one and made sure  it fit, this shows the difference. The finished one matches the dimensions of the old shoes.
I did the same for both shoes and also gave them a chamfer for the pivot pin, then I was able to install them without issue.
Now I just have to get a new sprocket and do some frame cleanup and it should be ready to go back on.
« Last Edit: November 24, 2024, 04:16:49 PM by cheddarGoblin »
1975 CB200T
1982 Nighthawk 650
1981 GL500
1971 CB500
1972 CL350
« Reply #91 on: November 27, 2024, 11:44:26 AM »
Do the shoe linings fit into the wear groove of the drum OK?
« Reply #92 on: November 30, 2024, 05:27:44 PM »
I'm not sure. Didn't occur to me to check and not sure that I know how to do so. I haven't reinstalled the wheel yet. Is there a way to mark the shoes to see where they are contacting inside the hub?
1975 CB200T
1982 Nighthawk 650
1981 GL500
1971 CB500
1972 CL350
« Reply #93 on: November 30, 2024, 05:38:19 PM »
Something that I am unsure of is the proper place for this seal.
The parts diagram shows one seal but it seems like I have one installed inside the bearing retainer and one installed in the sprocket side plate that I picked up from eBay since it was missing.
It seems like the sprocket side plate would be the place for it but not sure why it would fit into the bearing retainer as well.
1975 CB200T
1982 Nighthawk 650
1981 GL500
1971 CB500
1972 CL350
Offline Oddjob
« Reply #94 on: December 01, 2024, 05:29:02 AM »
Inside the sprocket dish is correct. The Oring also fits inside there, around the edge of the recession.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #95 on: March 20, 2025, 06:04:56 AM »
I had the same brake shoe issue.
I did the same thing and thinned them up a bit.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
« Reply #96 on: March 20, 2025, 07:44:35 AM »
Nice progress, do you still have your 750?
« Reply #97 on: March 24, 2025, 07:45:13 AM »
If the new linings are wider than a worn groove in the brake drum, the initial "wear" will be a lot in a few miles - as measured by how often you'll have to adjust the nut on the rear brake rod to get your pedal back to gripping the rear wheel. It will be wearing away the outer edges of the brake linings until the middle of them can contact the hub. The worst-case one I saw (it was on a CB450 IIRC) caused the rear wheel to 'stick' when little chunks of the new brake shoe got trapped in the edges of the drum's wear groove, but they eventually cleared away.
