Author Topic: 350F Wiring  (Read 654 times)
Offline sfhurst
350F Wiring
« on: March 15, 2023, 05:21:11 PM »
I have two issues.  First are some "extra" wires.  See the photo.  A heavy green wire with lug exits the main harness in the area of the electrics on the left side.  I have reviewed multiple wiring diagrams with no luck.  Where does it go?
In the same photo there appears to be an extra wiring in the three that connect to the turn signal blinker.  Two are obvious by color. The third is not. Is it extra for a three-connector blinker?
Last, black wires (with color tabs) exit the center of each front turn signal mount, but the wiring diagram shows a ground wire as well.  Where/how does this ground wire attach?
Thanks in advance for the always excellent help as I struggle through this resurrection of one 350F from three piles of junk.
Re: 350F Wiring
« Reply #1 on: March 15, 2023, 07:11:05 PM »
Green one with ring bolts to frame, dont forget to remove paint.
Spare green is fpr 3 wire blinker, indicstpts ground through thr casing amd what they are mounted on
