Author Topic: Spark Plug Wires  (Read 1193 times)
Offline Ellz10
  • ZZ
  • Knowledge is Power
Spark Plug Wires
« on: March 16, 2023, 02:41:55 PM »
Can't find the answer in the instructions or anywhere else.
I'm curious what the little metal bits are that came with my Dynatek Spark Plug Wire Kit. I circled them in the photo.
Thankful for everyone on this forum. Grateful to continue to learn so much.
'77 K7 - http://forums.sohc4.net/index.php/topic,193043.msg2251436/topicseen.html#new
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Spark Plug Wires
« Reply #1 on: March 16, 2023, 02:44:23 PM »
They screw on to the spark plugs
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Ellz10
  • ZZ
« Reply #2 on: March 16, 2023, 05:03:43 PM »
Wow. I am an absolute idiot.
Thank you.
« Reply #3 on: March 16, 2023, 10:31:40 PM »
Many plugs had them as default for many years ago.
Now part to purchase.
I got them too with my Dynatek wires that did not work.
One had intermittent function which I understood too late. Thought it was carb jetting issues. Graphite wires can be brittle if searching on it.
I changed to copper wires and NGK 5 kohm caps.
Stiff wires so the will stay in coils.  Soft will not, tried that with issues and bangs.
Strapped to frame, fuel hose around wire where strappad as extra insulation.
Soft wires can get loose when washing bike or the wind only. Happened to me too often.
« Last Edit: March 17, 2023, 02:08:21 AM by PeWe »
Offline Deltarider
« Reply #4 on: March 17, 2023, 01:13:08 AM »
I had them ferrules on top of my sparkplugs, because Dynatek plugcaps forced me. They proved unreliable, meaning: they loosened causing intermittent misfires. When I found out, I returned to NGK plugcaps which connect way better. By doing that, I could also abandon the R plugs, which are not a good choice for our bikes. The NGK caps have the resistor in the cap. Much better.
CB500K2-ED Excel black
Offline Ellz10
  • ZZ
« Reply #5 on: March 17, 2023, 08:21:01 AM »
I bought the NGK caps and installed them on the wires.
Should I forgo the little metal nubs then or do I still have to screw them on the spark plugs?
Offline Deltarider
« Reply #6 on: March 17, 2023, 08:26:32 AM »
You don't need them.
Offline Ellz10
  • ZZ
« Reply #7 on: March 17, 2023, 08:32:12 AM »
Awesome, thank you!
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #8 on: March 17, 2023, 09:48:22 AM »
the NGK spark plug boots are designed to fit over the threaded post. If you install the "post nuts" on the spark plugs then the NGK spark plug boots will not fit down over the top post of the spark plug.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #9 on: March 17, 2023, 11:53:03 AM »
NGK do both sorts of caps, on for with no fitting one for with
« Reply #10 on: March 17, 2023, 12:38:54 PM »
I could imagine that NGK would make spark plug boots for models that specify a (permanent) post nut type of spark plug, but if I ordered boots for a CB750 SOHC4 I would expect it to fit a threaded (bare) post.
TAMTF...
Wilbur
Projects:
« Reply #11 on: March 17, 2023, 10:49:49 PM »
Or if you order the NGK caps models you know will fit
NGK SD05F Resistor Spark Plug Cap black 8022
NGK Resistor Spark Plug Cap XD05F black 8072
There is a red version too.
Direct on plug threads.
I ordered several boxes (10 pack) Denso, NGK plugs, wires, connectors to Dyna coils,  extracaps for my bikes (CB750)  and more before BREXIT with extra customs +VAT ;)
https://www.gsparkplug.com/
« Last Edit: March 17, 2023, 11:01:37 PM by PeWe »
