Author Topic: 550 With 650 Cam, tach gear conundrum  (Read 603 times)
Offline exponent
  • Obsessed
« on: March 18, 2023, 08:04:59 AM »
So I have my 550 running with the 650 cam. Works great but the tachometer is off.
I have the 650 tach gear installed into the head but my meter is showing around 1k higher at idle. Anyone know which meter or meter gear will be accurate with this setup?
Thanks!
'78 550K 2106630
Re: 550 With 650 Cam, tach gear conundrum
« Reply #1 on: March 18, 2023, 09:25:56 AM »
The 650 tachometer can be used to get correct readings and I think if I recall correctly the 750 tach could also be used. The 650 tach has a black face.
Offline robvangulik
  • Honda Fourever
Offline Scott S
« Reply #3 on: March 18, 2023, 04:35:14 PM »
 You need a 650 or 750 tach.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
