I do not recall the brand of the electronic ignition, but it is a non-contact technology. It "knows" the position of the crank lobe via optical or magnetic or whatever. It is rock steady, and the coils are new NGK, I think. At any rate, ignition is no longer a source of potential problems. And, as I say, valves are adjusted as accurately as I can manage. I have adjusted these kinds of valves many time. Candidly, I prefer to use a dial indicator and holding fixture, but I don't see how that method can be used on these engines. I adjust valves on a vintage Porsche 911 sometimes using the dial indicator method.
I'll use the propane trick. Thank you. I have renewed the rubber things on both sides of the carbs. And, as I say, the carbs were professionally rebuilt including accelerator pump.
Idle is troubling on this bike. I really do think the carbs are way out of synch. Idle is all over the place, depending on air temp and engine temp and other factors. Part of what I will be doing is to make sure the cables connected to the carbs are all in adjustment, and all other exterior carb adjustments are proper. Even just adjusting the idle air is difficult or impossible because this engine just does not idle smoothly.
Only three carbs are adjustable. They all get adjusted to match #2.
CarbTune is a non-fluid tool, correct? I do want to avoid damaging the tool itself and if CarTune is a non-fluid type of tool, then my mind would be eased somewhat.
Thanks to all!
