You'll feel when it stops, a little bit more for copper seal to form.
Tighten all very loose to start with so all pipes will alugn correctly.
Tighten in steps until all are tight. Tighten each brackets 2 bolts so it will go on parallel.
You'll need to retighten after a ride or 2 when copper seals sets as usual.
I use alu paste on those threads. Withstands +1100C.
I use it on plug threads too, just a little.
Below my old Alfa 4-1 made for K0-K6.
The stainless Hindle 4-2-1 has stainless spigots that are bolted to head like stock K0-K6.
Pipes goes on section by section by ease if properly aligned and secured with springs. Take pipes off the opposite way, release springs on each section and final bolt at rear.
