I didn't want to remove the swing arm just to remove the chain.
I have used riveted chains since 2013.
No reason to open chain. That is an old myth for non CB750 owners.
I had that in my mind when I mounted a strong riveted chain for first time so I ordered 2 extra master links. I found a way to avoid open master link at wheel removal or pulling engine.
I have pulled engine twice on my K6 without open the extra strong riveted chain.
First chain was DC chains strongest with solid rivets. Need a good riveting tool.
Now strongest DID with hollow rivets. 530ZVMX. Cheaper reveting tool possible.
I ordered extra master links with chains just for sure if chain had to be opened or mistakes during riveting wich happened.
Only thing to do when removing rear wheel for replacement of tire/ wheel or pulling engine:
- Remove chain guard and cover on engine.
- Release and push wheel max forward for chain slack.
- Lift front sprocket off the outgoing axle with chain and push backwards. Work fine on my K6 and K2.
I do not know if later cases from K7-8, F2-3 with a protrusion at outgoing axle will be an obstacle, probably not.
Now can chain be lifted off rear sprocket and wheel can be taken off.
Or engine can be pulled out of frame.
My stock K2 has DID 530VX riveted chain.
I do not trust the clip chains. I remember close moments in the 80's when I found clip to be missing. Side plate still on since it sat hard.
The stronger chains have not clip option.
The stock restorer need old style to get it 100% stock. Maybe not much riding, more for display or ride to special meetings.
Crack the case due to a bad chain/missing clip will cost a lot in money and time.
