Author Topic: Johnie's 76 GL1000 Sulfur Yellow Build  (Read 23769 times)
0 Members and 13 Guests are viewing this topic.
Re: Johnie's 76 GL1000 Sulfur Yellow Build
« Reply #75 on: April 26, 2023, 02:52:12 PM »
Curious what it is/does
« Reply #76 on: April 26, 2023, 04:11:17 PM »
The barrel with two knurled lugs/ wire studs looks like an oil pressure sending unit. It would have been attached to a gauge. Looks like the fairing had oil pressure and temp gauges.
Offline Johnie
« Reply #77 on: April 26, 2023, 04:56:51 PM »
Agreed. I think I can take it off, but it screws into the back of the OEM sending unit so don't want to mess it up. That barrel thing completely covers up the engine number which is how WI titles these older bikes. I was able to see that number with a mirror to confirm it was a legit titled bike.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #78 on: April 26, 2023, 05:26:42 PM »
It looks like the sender from VDO that I used on my old 66 Volvo 122S or one of the many 240 Volvos which I fitted with oil pressure gauges. The sender has both the variable output pressure gauge and the low pressure switch outputs. The stock oil pressure switch sender is just the low pressure switch sender.
You will need a plug on your motor if you remove it. The flats of that sender on the VDO model senders were stamped with the pipe thread pitch the end was threaded.  Not sure if that’s precisely what you are dealing with or another brand. VDO part number was on another flat of the sender bolt head.
Offline Johnie
« Reply #79 on: April 26, 2023, 05:47:02 PM »
Yes, the OEM oil pressure switch screws into the top of the case. I would leave that in place. It's that other barrel thing...it screws into the back of the oil pressure switch. i would need that plug for the back of the OEM switch. I will leave it be for now, but will take that wire out of there.
Oshkosh, WI  USA
Offline Johnie
« Reply #80 on: April 27, 2023, 08:53:25 AM »
As my granddaughter says..."listen to this"... so about 8 years ago I went to an auction of a Honda dealer in southern WI. Got a lot of cool stuff, car was packed. Some stuff didn't know if I'd need, but it was all in a box for 1 auction bid. This included metric nuts, bolts, washers and a lot of fasteners which has come in real handy putting this GL back together. Couple boxes of repair manuals which I should list on this site. So I was going through some of the stuff and found an original owners manual and a first edition HONDA service manual for this GL. Then in the back of my mind I recall a front MC was in a box so checked that out and it was OEM front MC for this bike. The Gods were watching out for me...LOL  Still going to rebuild the 3 calipers and rear MC. Brake line from front MC to connection is cracked, but dealer locator shows none in the USA. I have about 6 used ones here that are pretty long that may work out.
Oshkosh, WI  USA
« Reply #81 on: April 27, 2023, 10:35:31 AM »
Always fun finding good stuff you never knew or forgot you had !
« Reply #82 on: April 27, 2023, 03:56:52 PM »
My buddy Gary used brake lines from Apex on both ends of his ‘75 Wing. Really improved the front brakes.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #83 on: April 27, 2023, 04:22:00 PM »
Are you a member at the naked Goldwings site (NGWclub.com/forums). Several of us here are also members there and it is a great site that is almost as active as this one.
Offline Bankerdanny
« Reply #84 on: April 27, 2023, 04:23:12 PM »
I've used Apex and was very happy, but my go-to now is Vehill, which uses screw on ends so are infinitely clockable.
Offline Johnie
« Reply #85 on: April 27, 2023, 04:51:22 PM »
Thanks Ben I will check out Apex. Are they stainless or why do you think they improved the brakes so much?
Oshkosh, WI  USA
Offline Johnie
« Reply #86 on: April 27, 2023, 04:52:08 PM »
Danny I am not a member but will join it tonight. Thanks a lot for the tip!
Oshkosh, WI  USA
« Reply #87 on: April 27, 2023, 08:42:39 PM »
Johnie, John recommends them because the Teflon braided stainless steel lines won't bulge at all giving a 1-to-1 on the fluid. Also no rubber insides to deteriorate and collapse when worn out. Overall a superior line. Some suppliers even have black outer rubber clad outer hose rather than the variety of clear or other commonly used polyurethane (I think) outer hoses.  They appear more like standard hoses.
No one is going to care as you aren't going to be showing the bike anywhere that the Teflon braided stainless hoses are going to get any demerits.
« Reply #88 on: April 28, 2023, 06:31:22 AM »
Raymond at Apex will build the lines any colour you want. I usually stick with black.
« Reply #89 on: April 28, 2023, 07:29:20 AM »
+1 for Apex...
http://www.apexbrakes.com/custom.asp
Offline Johnie
« Reply #90 on: April 28, 2023, 10:31:58 AM »
Joined...and thanks for the Apex info. Will be contacting him too.
Oshkosh, WI  USA
Offline Kelly E
  • Geriatric Hooligan
« Reply #91 on: April 28, 2023, 11:06:55 AM »
We've got Apex lines on over half of our bikes, great service.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #92 on: April 28, 2023, 11:32:28 AM »
How's their price Kelly ?
Offline Kelly E
« Reply #93 on: April 28, 2023, 01:22:54 PM »
The prices are fine, the Concours has Spigler lines but that was before I knew about Apex. All of the other lines we've replaced are Apex.
1983 Honda CB 1100F
« Reply #94 on: April 28, 2023, 03:03:23 PM »
Apex prices are the lowest I’ve found and the quality is second to none. Raymond has also made all the brakes hose for our race cars and they’re just as good!
« Reply #95 on: April 28, 2023, 03:11:34 PM »
Johnnie if you want those parts in MA I can ship them for you. Can pick up this weekend and ship next week. Let me know.
Offline Johnie
« Reply #96 on: April 28, 2023, 04:22:31 PM »
Thanks Andy...looks like Alan is getting them this weekend for me.
Oshkosh, WI  USA
Offline Johnie
« Reply #97 on: April 30, 2023, 01:31:34 PM »
Took that strange contraption off behind the oil pressure switch. Must’ve had something to do with the fairing.
Oshkosh, WI  USA
« Reply #98 on: April 30, 2023, 01:39:20 PM »
A gauge rather than a light;I prefer a gauge.
« Reply #99 on: April 30, 2023, 05:02:52 PM »
Definitely an oil pressure sending unit, hooked up to an electric oil pressure gauge. Looks like an old VDO unit.
