« Reply #103 on: May 01, 2023, 01:53:51 AM »
Did you pop the timing belt covers and check the belts and tensioner? Your shop looks very “comfortable”.
Looking at the belts won't do much. If the belts are over 5 years old they need replacement as the rubber hardens up and the bends get set, belt failure is bound to happen at the worst of times and high cost to rebuild the motor is not worth the $50 savings......unless you like playing Russian Roulette.
![](http://forums.sohc4.net/Themes/default/images/ip.gif)
Logged
