Author Topic: Johnie's 76 GL1000 Sulfur Yellow Build  (Read 25451 times)
Re: Johnie's 76 GL1000 Sulfur Yellow Build
« Reply #125 on: May 05, 2023, 05:10:49 PM »
Looking good Johnie! It will be a nice running and riding bike when you are done!
Looking like it has been an interesting project as well.
« Reply #126 on: May 05, 2023, 05:14:39 PM »
I bought parts for my GL1000 carbs from Randaak. Years ago, I think I bought his carb manual and a video too! I think it was a VHS tape. I might still have it? Will have a look.......
Offline Johnie
« Reply #127 on: May 05, 2023, 06:25:58 PM »
Ordered my Gates T274 timing belts today. Will take the covers off this week when I get the radiator removed to change the upper and lower hoses. Will check out those pulleys too. All good ideas...keep them coming...
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #128 on: May 06, 2023, 02:25:52 AM »
Here's a pdf on how to rebuild your tensioners with new pulleys
https://www.goldwingfacts.com/attachments/tensioner-rebuild-jcs-pdf.307373/
« Reply #129 on: May 06, 2023, 08:03:23 AM »
Looks like a pretty involved carb setup. Sure calls for a manual.
Offline Johnie
« Reply #130 on: May 06, 2023, 08:10:19 AM »
Agreed...a manual or an expert. Randakk said they also fix a low idle issue that was customary in the first generation Wings.
Oshkosh, WI  USA
Offline Johnie
« Reply #131 on: May 06, 2023, 08:11:23 AM »
Newday thanks a lot for the info on rebuilding the tensioners. I'll check them out.
Oshkosh, WI  USA
Offline Johnie
« Reply #132 on: May 06, 2023, 08:28:19 AM »
You know one gets so used to doing the 750's they become routine. It's actually fun to work on something different now.
Oshkosh, WI  USA
« Reply #133 on: May 06, 2023, 05:27:54 PM »
Randakks used to have a tips section on the website 12-13 years ago when I rebuilt my 83 GL1100 carbs. Hopefully they still have it since Randall sold it off to the conglomerate corporation.
« Reply #134 on: May 06, 2023, 05:37:41 PM »
You are welcome bro.
And yes it is fun to bring back a different bike to life. I've brought back the 83 GL1100, a 98 and a 99 GL1500 and and worked on a few GL1800s.
Today I went and looked at an 85 GL1200 LTD(fuel injection) with 63,000 miles on it.
It needs head gaskets, tires(good treads but from 2000!) and a few body pieces. It'd be a fun ride, But I have half a dozen CB750s in the que to bring back so I may not jump on that wing????? More than enough projects, not enough room for another project, time or money.....
Online grcamna2
« Reply #135 on: May 06, 2023, 06:27:31 PM »
Stu,a fuel injected GL1200 ?
« Reply #136 on: May 06, 2023, 10:17:19 PM »
Yes 2 years only.
1985 GL1200 LTD Gold 2 tone
And also the 1986 GL1200 SEI beige 2 tone
1986 SEI
« Last Edit: May 06, 2023, 10:39:21 PM by newday777 »
Offline Johnie
« Reply #137 on: May 07, 2023, 06:27:10 AM »
Those are really nice Wings. I sold my 2000 SE a couple years ago. Wife wasn't that interested to ride anymore and I really like the 750's. I have to admit these 80's bikes you showed really do have a nice look to them. Sound good too.
Oshkosh, WI  USA
« Reply #138 on: May 07, 2023, 08:02:08 AM »
The older Wings looked somewhat assembled, the new ones look moulded, they seem seamless.
Online Alan F.
« Reply #139 on: May 07, 2023, 08:32:17 AM »
He's actually a member here. If you can't find the info maybe he can help you out? Seemed like a good guy last time I interacted with him on the twins forum.
http://forums.sohc4.net/index.php?action=profile;u=57656
Offline Johnie
« Reply #140 on: May 07, 2023, 05:20:03 PM »
Got the rediator and timing covers off today. Pics for your review with info from HONDA on the belts. Does the 7-13 mean that is the mfg. date of the belt? If so they haven't been on here very long. No cracks anywhere I can see. Some oxidation in the area and some rust on the OS of the gears. Thoughts?
« Last Edit: May 07, 2023, 05:26:40 PM by Johnie »
Oshkosh, WI  USA
« Reply #141 on: May 07, 2023, 05:22:53 PM »
You can not tell if they are good by looking at them.
If older than 5 years replace them....or do you like Russian Roulette?
Offline Johnie
« Reply #142 on: May 07, 2023, 06:34:18 PM »
So you guys are replacing these every 5 years or does mileage go into the equation too?
Oshkosh, WI  USA
« Reply #143 on: May 08, 2023, 02:57:01 AM »
Mileage is OK if the bike is constantly in use. If it has slept in lack of use for a long time and the rubber hardens with age it sets the curvature to the pulley diameter. That set size comes into play when you bring the bike back to life and each time the belt goes around the revolution, it weakens the belts where it set to the diameter around the pulleys and will break at some unknown time. Is it really worth your saving a few bucks at this time when a belt breaks and you end up with tagged pistons to valves bending valves at minimum and at worst case scenario you get broken valves and I have seen cracks and holes in pistons(split the cases to get bits of pistons from the cases). It's not a pretty picture when a belt breaks on these interference motors.
Not knowing the history of a motor is my first choice to change the belts immediately.
By the way, I've bought belts from Rock Auto for $16 each(might be more now but not what you paid of $50 for 1 belt).  Go to the website and do a search for the belt number.
« Last Edit: May 08, 2023, 02:58:58 AM by newday777 »
« Reply #144 on: May 08, 2023, 05:22:53 AM »
I’d replace the belts so you know they are new. Check the tensioner pulleys carefully too. You also mentioned the “0” rings on the coolant tubes? I didn’t and ended up doing them soon after......
The other part that needed attention on my last ‘75 was the water pump. Shortly after “waking up” that bike, the front vent hole started dripping water. These pumps have internal seals that keep oil in the crankcase and water in the pump separate (pump takes it’s drive out of the sump ). Watch it on start up.
« Reply #145 on: May 08, 2023, 07:36:25 AM »
Wise advice indeed!
Offline Johnie
« Reply #146 on: May 08, 2023, 08:16:08 AM »
Thanks much for the insight to the belts. I did order the Gates T274 belts today. The water pump and coolant tubes O rings are coming too. Thermostat they are listing like 7 different ones depending on serial number. What's that all about heat range? So the 19300-PB2-023 is listed at a number of dealers on the parts locator.
Oshkosh, WI  USA
Offline Johnie
« Reply #147 on: May 09, 2023, 07:23:52 AM »
Thermostat coming. Quick question which was not answered in my HONDA service manual. The O rings for the overhead coolant tubes...just slide them on or should I be using a little RTV or some other sealant on those. Same question for the 2 bolt mounts that the coolant tubes mate too. Same question for the thermostat housing and lower radiator hose housing. I see Honda only uses an O ring for those...dry or sealant? Water pump housing? Probably dumb questions, but I hate to have a leak when all is done. Thx guys...
« Last Edit: May 09, 2023, 07:27:05 AM by Johnie »
Oshkosh, WI  USA
« Reply #148 on: May 09, 2023, 07:47:11 AM »
From memory, I just really cleaned the parts and used a bit of grease on the “0” rings to make sure they slipped in smoothly. No leaks.
I use a bit of sealant on any water pump gasket. Probably Hondabond, and very little.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #149 on: May 09, 2023, 09:45:37 AM »
I did the same, although I got the DVD, which I somehow managed to lose after the carbs were done, although helpfully I still have the case it came in.
