Author Topic: Fork Flex  (Read 993 times)
Offline BrickWoll
Fork Flex
« on: April 02, 2023, 09:32:20 AM »
Hey all,
Is it by design that 550 forks flex forward and rearward a bit under normal road chattering?  This movement is a little disconcerting when I'm looking down at it.  Forks and triple are stock '77 CB550 K3.  Forks are lowered about 1.5".
Thanks!
'77 CB550 K3
Re: Fork Flex
« Reply #1 on: April 02, 2023, 09:38:44 AM »
 Those are probably the same #341 lowers the 750's use but with a shorter chrome tube. I wouldn't expect to notice flex. Check the top tree clamps for broken loops where they clamp onto the tubes.
 (The reason I mention it is, my 750 had modified 550 triples and both sides were broken)
« Last Edit: April 02, 2023, 10:45:54 AM by Don R »
Re: Fork Flex
« Reply #2 on: April 02, 2023, 10:42:09 AM »
What front fender is fitted?
Offline ofreen
Re: Fork Flex
« Reply #3 on: April 02, 2023, 11:38:27 AM »
Some fore and aft flexing is visible even with forks with thicker tubes than the spindly ones on our old bikes. Sight along the tubes when you apply some front brake. You will see some deflection. Disconcerting? Just another one of those things that’s best not to think about when riding down the road with any of a myriad of mechanical failures that could happen at any moment resulting in you wearing your bike as a hat. ;)
It wouldn’t hurt to check steering head bearing adjustment, though.
Greg
'75 CB750F
Re: Fork Flex
« Reply #4 on: April 02, 2023, 12:13:59 PM »
I had a badly worn front tire that caused fork tube flexing in higher speeds.
Offline newday777
Re: Fork Flex
« Reply #5 on: April 02, 2023, 01:29:03 PM »
+1
Without the front fender you loose stability built into the fender brace.
Stu
My current rides
Prior bikes....
Online Tracksnblades1
Re: Fork Flex
« Reply #6 on: April 02, 2023, 01:35:20 PM »
I’d check for fork spring spacers…not sure if it was a 550 thing or not..
Ran across a 4 inch set in a 75k.  Forks wouldn’t compress unless you used the front brake…
Age Quod Agis
Offline BrickWoll
Re: Fork Flex
« Reply #7 on: April 02, 2023, 03:53:04 PM »
Thanks, Don. Not exactly sure what I'm looking for.  I don't see any obvious cracks in the top tree.
'77 CB550 K3
Offline BrickWoll
Re: Fork Flex
« Reply #8 on: April 02, 2023, 03:53:46 PM »
Stock fender (bobbed).
'77 CB550 K3
Offline BrickWoll
Re: Fork Flex
« Reply #9 on: April 02, 2023, 03:55:03 PM »
Thanks PeWe, but just got new rubber at the end of the last riding season.
'77 CB550 K3
Offline spotty
Re: Fork Flex
« Reply #10 on: April 02, 2023, 05:13:23 PM »
my first 750 ( K2 ) had longer forks ( about 5 inches or so ) and would flex around 3-4 inches at the wheel. i cured this by not looking down there  ;D
i blame Terry
Re: Fork Flex
« Reply #11 on: April 02, 2023, 07:08:39 PM »
You ever notice that the only modern motorcycle that still has 35mm fork tubes is a hell of a lot smaller and lighter than a cb550?  hmmm?...
Offline spotty
Re: Fork Flex
« Reply #12 on: April 02, 2023, 07:17:18 PM »
whats worse is they kept using them right up into CB900s
i blame Terry
Re: Fork Flex
« Reply #13 on: April 02, 2023, 10:16:39 PM »
 This, Except I didn't notice any flex.
« Last Edit: April 02, 2023, 10:20:17 PM by Don R »
Re: Fork Flex
« Reply #14 on: April 03, 2023, 07:29:19 AM »
Isn’t that what happens when those clamp limiter washers aren’t installed and the bolts over tightened?
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Fork Flex
« Reply #15 on: April 03, 2023, 07:44:41 AM »
Ouch, scary!
1973 CB 750 K3
10/72 build Z1 Kawasaki
Re: Fork Flex
« Reply #16 on: April 03, 2023, 08:40:00 AM »
   In this case, both sides had the D washers, but the bolts were extremely tight. This was a set of 550 trees on a 750 frame, the neck had been welded to make it long enough. Apparently, he wanted the smaller 550/500 offset. It's a road race thing I guess.
Offline Ichiban 4
  • "Ichi"
Re: Fork Flex
« Reply #17 on: April 03, 2023, 11:28:22 AM »
When I bought my '77 550K years ago..it had that 'fork flex' thing going on that Brickwoll was talking about earlier..same thing..high speed wobble..seemed to be above 50 mph..if memory serves me.
My solution was to install a fork brace from Spec II in So. Cal.  Not sure if they're still in business but URL to their website is: http://www.spec2.com/clips.html#apps
Since that time (over 20 years ago)..I never noticed the high speed wobble anymore..so seems to have fixed it.
I also think that there are other brands of fork braces available..or that were made..that would probably do the same thing as the Spec II brace that I got.
Ichi
Al Summers
Present: '77 550K
Offline Shtonecb500
    • Youtube profile
Re: Fork Flex
« Reply #18 on: April 03, 2023, 02:48:34 PM »
I had lots of fork flex when my springs went bad.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline BrickWoll
Re: Fork Flex
« Reply #19 on: April 03, 2023, 04:21:00 PM »
Yeah - that's all bad.  If the bolts on the bottom triple loosen, the riding position gets real aggressive real fast.
'77 CB550 K3
Re: Fork Flex
« Reply #20 on: April 03, 2023, 08:07:31 PM »
Ichi
Back 'in the day' we used several things to reduce the wobble of the 500/550 at hiway speeds when the tires were a little 'flat' in the center from wear/lack-of-care issues.
The $5 'fix' was to install cut pieces of [electrical conduit] pipe into the forks, against their springs, to raise the front end, as it was sprung too soft for all but the lightest of riders. Essentially, this restored the lost trail, which was marginal when new, in the front: this improves stability naturally.
The $50 'fix' was the fancy  stainless-steel 'hoops' that were the over-the-fender fork brace (I've forgotten the maker) that was a show-stopper. It worked REAL well, but they never made one for the 750. (Dang...) I also added spring shims (usually 3 thick washers on each side) when installing these, and it gave the bikes a little more aggressive-looking stance, if it did make them lean over further on the sidestand.
Re: Fork Flex
« Reply #21 on: April 04, 2023, 12:44:49 AM »
Tricky with a fork brace for the 341 lowers CB750 K2-K6. Probably the earlier too.
It has been a variant before with stock fender in place
http://forums.sohc4.net/index.php?topic=103654.0
Another thing is a clamped one as this.
https://carpyscaferacers.com/shop/shop-our-store/motorcycle-parts-accessories/honda-cb500-cb550-cb750-parts-upgrades/alloy-fork-brace/
I doubt it can sit that close to the lowers. A deep road bump need some dampening. Not a hard sudden bottom out.
But it must improve  even if sitting a little higher.
« Last Edit: April 04, 2023, 01:06:29 AM by PeWe »
Offline spotty
Re: Fork Flex
« Reply #22 on: April 04, 2023, 06:44:57 PM »
having the front guard/clamps/over the top hoop in place aren't going to do much for back /front flex, as said above its the cr4ppy long thin tubes that are flexing backwards and forwards.
all the above will stop or reduce lateral twisting which basically occurs between the axle and the lower triple clamp so having a stiffening method between those points will eliminate ( or at least reduce ) twisting
and like i said above, if you don't look at it then all is good.....
i blame Terry
