Author Topic: 1978 Honda CB 550 Four AC generator hot.  (Read 1023 times)
Offline briancairns
« on: April 02, 2023, 01:00:45 PM »
Hi,
I live in Ireland and have an American import 1978 Honda CB 550 Four.
Bike fully serviced , carbs refurbished and  balanced . Electronic ignition fitted. All fully serviced by experienced motorcycle mechanic.
However the AC generator stator coil burned out and got it re-wired as a new one is extremely expensive.
Bike starts ok but idle will not go below 2000 rpm when warm no matter what the mechanic does.
Also can't get bike to go above 60 mph however the engine seems smooth.  When running can't get the bike above 5000 rpm but in neutral it revs to whatever I want it to.
Also after a 60 mile run today , I touched the casing of the AC generator and it was red hot! ( burned my hand).
My mechanic is now totally baffled but admits he is not experienced with this bike.
Can anyone advise?
Thanks in advance
Brian
Offline newday777
Re: 1978 Honda CB 550 Four AC generator hot.
« Reply #1 on: April 02, 2023, 01:25:10 PM »
Welcome aboard Brian from across the pond north of Boston in New Hampshire.
How long did it set while you had the stator rewired? I ask as it sounds like you have clogged carbs. It only takes a few weeks setting with gas in the carbs to start hardening the gas left in the tank and carbs today with ethanol gas.
Have you cleaned the tank of rust? Even surface rust will put off tiny particles into the carbs. Pull the bowls and inspect for junk.
It sounds like the re-wiring wasn't done correctly causingtheoverheating. I'm not up on the 550 so I'll defer to others that will come along.
Stu
My current rides
Prior bikes....
« Reply #2 on: April 02, 2023, 01:47:46 PM »
Isit a K or an F model, K was fitted with pd cbs and they are notorious for cloggingand those symptoms.
As to generator all the 500/550 coils are the same but check the charging voltage as it may be fully charging all the time
Offline briancairns
« Reply #3 on: April 02, 2023, 01:53:15 PM »
Ok thanks Newday and Bryan, will check the carbs again. What would cause continuous charging?
Cheers
Brian
Offline briancairns
« Reply #4 on: April 02, 2023, 01:54:25 PM »
Sorry it’s a K model
Offline 69cb750
« Reply #5 on: April 02, 2023, 03:42:14 PM »
Regulator failed.
Offline briancairns
« Reply #6 on: April 02, 2023, 03:47:59 PM »
Thanks.
Would this cause the stator coil to burn out? The AC generator casing was red hot to touch and have already burned out a stator coil or would the regulator have a bad earth ?
Cheers
Brian
« Reply #7 on: April 02, 2023, 07:07:46 PM »
the generator cover will be as hot as the engine,that is itll be untouchable when hot.
Offline briancairns
« Reply #8 on: April 02, 2023, 11:51:12 PM »
Thanks Dave…that would then be normal?
Thanks
Brian
Offline newday777
« Reply #9 on: April 03, 2023, 02:15:26 AM »
Thanks
Brian
You should buy or borrow a non contact Infrared Thermometer Gun to test the temperature differences of the alternator cover and the other parts of the motor
Stu
My current rides
Prior bikes....
Offline briancairns
« Reply #10 on: April 03, 2023, 02:28:25 AM »
Ok thanks. I actually have one !
Brian
« Reply #11 on: April 03, 2023, 04:49:04 AM »
As to carbs, have seen them needin ultrasonic 3 or more times plus the press in pilot jets need to come out
Offline briancairns
« Reply #12 on: April 03, 2023, 10:12:40 AM »
Ok thanks
Cheers
Brian
Offline grcamna2
« Reply #13 on: April 03, 2023, 01:36:08 PM »
Those PD carbs on your model 550:do they also have an accelerator pump ?
75' CB400F/'bunch o' parts'
« Reply #14 on: April 03, 2023, 03:28:14 PM »
Only 650 and 750 have the pumps 550 no
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #15 on: April 03, 2023, 03:46:47 PM »
Check battery voltage when running, see if it’s over about 13.5 or so.
Check for leaks around the carbs, air leaks will raise the idle.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline briancairns
« Reply #16 on: April 04, 2023, 04:17:56 AM »
Thanks all,
Bike booked with mechanic but will be doing some basic tests myself tonight.
Thanks all
Brian
