Author Topic: Cb650 brake bleeding  (Read 405 times)
Offline club_c
« on: April 04, 2023, 02:18:45 PM »
I just changed out the front brake master cylinder on my 1980 CB650. I cannot get to a solid lever, it seems there is air in the system but cannot purge it. I’ve done lots of brake bleeding in the past. This one seems to elude me. Any good techniques unique to this model?
Offline newday777
Re: Cb650 brake bleeding
« Reply #1 on: April 04, 2023, 03:33:56 PM »
First off you need to bleed the master banjo bolt of air just as if it's a bleeder. Then bleed the caliper after.
Stu
My current rides
Prior bikes....
Offline fizzlebottom
« Reply #2 on: April 04, 2023, 03:54:38 PM »
Do you have the original rubber hoses?
If so, those might be your problem. They shed the inner lining and end up bulging under pressure. I had this exact issue when I was doing my front brakes many years ago, even after a new mastery cylinder and like 2 hours of bleeding. I had SS brake lines fabbed up by a local dude and my front brake was 100% fixed.
1982 CB650SC Nighthawk
Offline scunny
  • don't call me expert
« Reply #3 on: April 04, 2023, 05:50:30 PM »
on my 650 withe duel discs, i had to use a 50cc syringe to bleed the calipers, worked a treat.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline newday777
« Reply #4 on: April 04, 2023, 11:11:18 PM »
Did you get it working?
Stu
My current rides
Prior bikes....
