Author Topic: Tank sealer  (Read 1175 times)
Offline Dreadnought
Tank sealer
« on: April 07, 2023, 03:33:41 PM »
Many brands my tank sealer I used about 5 years ago is starting to fail. Any consensus out there of the best on the market?
Offline Magpie
Re: Tank sealer
« Reply #1 on: April 07, 2023, 05:07:19 PM »
I've used Por15 with good success.
Offline Slow2
  • 1971 CB750, 1974 Cb750, 2004 Yamaha Roadstar chopp
Re: Tank sealer
« Reply #2 on: April 07, 2023, 05:17:38 PM »
The best I’ve used is Caswell. But follow the instructions!!
Offline dusterdude
Re: Tank sealer
« Reply #3 on: April 08, 2023, 03:17:22 AM »
Me too
Sent from my SM-G973U1 using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Re: Tank sealer
« Reply #4 on: April 08, 2023, 04:24:33 AM »
Gotta follow POR’s instructions to the letter and tank needs to be bone dry before you use their sealer.
Offline pjandrew99
Re: Tank sealer
« Reply #5 on: April 09, 2023, 02:24:23 AM »
I've tried both Red-Kote and Caswell. Both failed eventually but think I learned a few things. The Red-Kote failure was a tank that was very narrow toward the back. I believe the Red-Kote accumulated in that area and never set up. Still my fault but I didn't like the product.
Caswell was a little thicker than I thought it would be. Next time I will dilute it and use less. I liked it and would try it again.
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
Offline BenelliSEI
  • 1969 cb750
Re: Tank sealer
« Reply #6 on: April 09, 2023, 03:31:09 AM »
Only used it once, but worked well. Followed the instructions to the letter!
Offline rotortiller
Re: Tank sealer
« Reply #7 on: April 09, 2023, 04:04:39 AM »
POR15 worked for me, I've got 7 years on it and it still looks like the day I did it. Rather than take any chances on other products I would use it again. Like anything someone will certainly manage to mess it up lol!
« Last Edit: April 09, 2023, 05:11:26 AM by rotortiller »
Re: Tank sealer
« Reply #8 on: April 10, 2023, 08:16:20 AM »
I've tried both Red-Kote and Caswell. Both failed eventually...
My [old] painter talked me into using Caswell when the tank was painted, it failed a few years later.  Removed it and used Evaporust on the tank and it was fine afterwards.
Bottom line - unless your tank has pin holes in it, you may not need to line it and risk failure.
Offline carnivorous chicken
Re: Tank sealer
« Reply #9 on: April 10, 2023, 09:04:43 AM »
I've used POR15 and Redkote with no issues. I've got a POR15 tank that's been going for maybe 20 years. But as others have pointed out, gotta follow directions to the letter, tank's gotta be bone dry before sealing.
Offline AMT
Re: Tank sealer
« Reply #10 on: April 13, 2023, 07:55:35 AM »
A great way to make sure your tank is completely dry is to find a hair dryer with a nozzle that fits nicely in the fuel filler hole. Be careful with the amount of heat - low to medium works well, enough to feel the tank is warm to the touch. Let it run for while, 10-15 minutes and be sure that air is circulating out the bottom (petcock removed).
I recently did this to a tank I was prepping to coat with POR-15. It was so dry that I decided to let it sit overnight just to see if any flash rusting would occur. None did.. so I filled it with gas, put it back on the bike, and saved the POR kit for a future tank that has pin holes or more serious issues.
