Author Topic: Cylinder head cover removal question cb550  (Read 343 times)
Offline opp750
« on: April 09, 2023, 07:04:45 AM »
I'm looking to remove the cylinder head cover and breather cover on my 75 cb550 and paint it. My question is – is it as simple as removing, masking off the parts I don't want the paint to get on, and reinstalling it with a new gasket? Or will I need to readjust the valves or something after it's been pulled off?
Offline calj737
  • I refuse...
Re: Cylinder head cover removal question cb550
« Reply #1 on: April 09, 2023, 07:40:43 AM »
You will need to adjust the valves afterwards, but you MUST release the tappets prior to removing, and use rubber bands looped over the intake/exhaust tappets during removal to prevent a bent valve.
The rocker arms (tappets) are attached to the underside of the cover, not part of the head. That is why the procedure differs.
Offline opp750
« Reply #2 on: April 09, 2023, 10:49:16 AM »
I had a feeling it wouldn't be as easy as that. Thanks for the info.
Offline newday777
« Reply #3 on: April 10, 2023, 10:47:10 AM »
How about the cam chain? Doesn't it go through the head and cam gear or is the cam lower than the head? I'm not familiar with the 500/550 internals.
Stu
My current rides
Prior bikes....
« Reply #4 on: April 10, 2023, 01:14:50 PM »
The cylinder cover has all the rockers.  The cam is in the cylinder head proper.  Stays there with just a cylinder cover removal.
But, that cylinder cover install has risk of bending valves if care not taken to keep tappet adjusters off the sides of the valve stems.
« Reply #5 on: April 10, 2023, 02:43:17 PM »
No gasket but a shaped O ring
