Author Topic: 78 carb problem.  (Read 3321 times)
Offline Supersportguy
78 carb problem.
« on: April 24, 2023, 07:57:30 AM »
Restoring a 78 750A. Have cleaned the carbs and still only runs on choke. I have cleaned and eventually replaced the slow jets with new #38 jets. Still have the same problem. Also have sprayed carb cleaner thru passage ways to be sure they are clear. Pilot jets are set at 1 1/8 turns out. This is crazy! Have never had this problem before. Floats set at 12.5. Main jets cleaned. The only thing I noticed is when I go from neutral to drive the accelerator pump does not activate. It does on my 76.
Offline newday777
Re: 78 carb problem.
« Reply #1 on: April 24, 2023, 08:49:28 AM »
Are the accelerator pump jets all squirting properly??
Stu
My current rides
Prior bikes....
« Reply #2 on: April 24, 2023, 11:57:44 AM »
Yes, there is only one pump, on the #2 carb.
Offline newday777
« Reply #3 on: April 24, 2023, 02:48:38 PM »
It should squirt out in each carb, does it?
Stu
My current rides
Prior bikes....
« Reply #4 on: April 24, 2023, 07:21:41 PM »
Can I test that with the carbs off the bike?
Offline newday777
« Reply #5 on: April 24, 2023, 10:59:27 PM »
Yes if you have a carb stand and a test gas bottle to have a feed to the bowls.
Stu
My current rides
Prior bikes....
« Reply #6 on: April 26, 2023, 03:08:50 AM »
I found that number three is totally blocked.  Will clean out and retest. Hope that's my problem.
Offline Alan F.
« Reply #7 on: April 26, 2023, 10:34:12 AM »
Good catch.
« Reply #8 on: April 26, 2023, 06:12:04 PM »
I had a 78F once that acted like yours after the owner rebuilt the carbs. He had put the O-ring into the idle-adjuster screw holes on the bottom of the tiny washer in there, instead of having the O-ring on top of it. It would start and run, but below 1800 RPM it would die. Sound familiar, maybe?
The O-ring goes in first, then the washer. I usually stack them on the air screw with the washer resting against the 'step' on the screw and then guide them up into place that way. Easy does it! ;)
Offline Magpie
« Reply #9 on: April 27, 2023, 07:53:29 AM »
I had a similar problem with my 78F. It would start on the choke then die. No idle possible. I went through the carbs and installed a new accelerator pump - still no go. It sounded like it was starving for gas or way too lean. New carb manifolds/insulator solved my problem. I think it was sucking air past the rock hard old ones. Cliff.
Offline sandcastcb750
« Reply #10 on: June 24, 2023, 01:01:47 PM »
My CB750 K8 had the same carb issue; only ran on choke. Jets must be removed and cleaned well. This is a result of EPA requirements and Honda designed a press fit design that stinks.
« Reply #11 on: June 24, 2023, 06:59:35 PM »
Yeah, it was the US DOT, pushed by the US EPA, that forced Keihin (and many other carb makers) to switch to the press-in type jets (witness Holley, Rochester and Carter automotive carbs of the same era). At least Keihin was smart enough during that episode to increase the authority of the air screw at the same time, giving it almost a full turn of range where it works. In the earlier carbs you only get 1/2 turn (3/4 to 1-1/4) of active adjustment, beyond which only a jet change will make a difference.
