Author Topic: Running lights question  (Read 497 times)
Offline JDrider
  • Slowly becoming an uncertified cb550 mechanic
« on: May 01, 2023, 08:08:17 AM »
I have a 1975 Cb550 K1.
When the headlight is turned on, the two front turn signals also light up.
Is there anything on the rear of the bike that is supposed to light up also?
JD
1975 CB550K1
Re: Running lights question
« Reply #1 on: May 01, 2023, 08:24:25 AM »
Simple answer.   NO
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: May 01, 2023, 08:27:11 AM »
Rear facing running lights in most places have to be red. Rear amber lights are turn only.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline JDrider
« Reply #3 on: May 01, 2023, 08:41:13 AM »
Simple answer.   NO
The reason I ask is because it didnt pass inspection because I was told there is supposed to be a running light on the rear.
JD
1975 CB550K1
« Reply #4 on: May 01, 2023, 08:51:30 AM »
Tag light qualifies as rear running light. Need a different inspector, this one clearly is applying modern rules to vintage bikes. Rear brake light also lights up showing running lamp. So, your 8nsoector has a screw loose. Bike not running doesn't require all lamps required for running. Park lights are a different concept...
Offline JDrider
« Reply #5 on: May 01, 2023, 08:53:39 AM »
So the rear brake light is supposed to light up with the headlight on?
This is what I'm trying to figure out.
JD
1975 CB550K1
Offline robvangulik
  • Honda Fourever
« Reply #6 on: May 01, 2023, 09:02:51 AM »
The rear has a duplo lamp, the 5 watt should light with ignition on (if you do not have a lights on/off switch) en the 21 watt works when braking.
« Reply #7 on: May 01, 2023, 09:03:04 AM »
If the headlight is on the rear brake light should be on in 'running' light mode. Gotta see your rear in the dark.
Offline JDrider
« Reply #8 on: May 01, 2023, 09:04:40 AM »
Ok, good to know. I will check this.
Thanks.
JD
1975 CB550K1
« Reply #9 on: May 01, 2023, 09:08:30 AM »
Thanks.
Correct. The rear tail light is dual filament, one for running light and the other filament lights up brighter when brake is applied. Definitely need a tail light! I have considered converting the rear turn signals to dual filament with red lenses just in case the single rear tail light bulb fails.
TAMTF...
Wilbur
Projects:
Offline newday777
« Reply #10 on: May 01, 2023, 10:40:31 AM »
Simple answer.   NO
So the running light in the tail/brake isn't working?
Stu
My current rides
Prior bikes....
Offline JDrider
« Reply #11 on: May 01, 2023, 10:43:31 AM »
Simple answer.   NO
Correct, I will double check this when I get home.
JD
1975 CB550K1
« Reply #12 on: May 01, 2023, 11:17:45 AM »
 Yes, a taillight.
« Reply #13 on: May 01, 2023, 12:24:44 PM »
TAILIGHT comes on with headlamp BRAKELIGHT comes on with brakes, 3 wires to rear light
Brown = TAILIGHT
Green  = Ground
Green/yellow = Brakelight.
Buld is a 5/21 w 12volt staggered pin
« Reply #14 on: May 01, 2023, 12:28:08 PM »
When tail light stopped working I usually adjusted brake light to be lit as tail light.
Replaced bulb asap
Offline BenelliSEI
  • 1969 cb750
« Reply #15 on: May 01, 2023, 04:28:29 PM »
Replaced bulb asap
I know a guy that’s so nervous about a burnt out tail light, he lightly silicones a spare inside his tail light lens! I can usually spot it when we’re stopping, even in day light. I just don’t ride at night.
