Author Topic: CB550 Negative Tank Pressure  (Read 663 times)
Offline DJPrototypikal
« on: May 02, 2023, 02:55:37 AM »
Hi all
With a re-lined tank, new locking gas cap, and low fuel - I am experiencing negative pressure buildup  in the tank which stops fuel flow.
Does anyone know if the gas caps should handle negative pressure, or if there is a method of venting the tank that I missed?
P.S. After sitting in a garage for 15+ years, it passed its safety yesterday! This is the 2nd last issue before going on the road….
Thank you. Niall
Offline jlh3rd
  • "just who gets to determine my needs?
Re: CB550 Negative Tank Pressure
« Reply #1 on: May 02, 2023, 04:12:14 AM »
sounds like the gas cap vent isn't working. I'm unfamiliar with the "K" model caps....if that's what you have...
The "F" model cap I could show you the vent.....
"alleged greed is usually a lazy person's opinion"
Offline Nurse Julie
« Reply #2 on: May 02, 2023, 04:22:38 AM »
Sounds like the vent in the cap is blocked. Take it apart and give it all a good clean.
Trust me I'm a Nurse, I promise it won't hurt....much
« Reply #3 on: May 02, 2023, 04:41:55 AM »
New gas cap from Common-Motors. I’m assuming new ones vent positive and negative pressure.
There is one screw on the underside. On pretty tight. I’ll see if it comes off.
Thanks.
« Reply #4 on: May 02, 2023, 05:18:28 AM »
I'm sure you have cleaned the carbs well but they also have air vents also that need to be clear if the cap is good. Does everything work normally when the bike is running and the gas cap is left open a little ?  Fuel line routing good and are you doing any inline filters ?
« Last Edit: May 02, 2023, 05:22:26 AM by ekpent »
Online PeWe
« Reply #5 on: May 02, 2023, 05:25:46 AM »
I had under pressure in a CB750 K2 tank. When warm tank with fuel cooled off after a ride, under pressure happened. Bubbling in carbs too. ;)
The gasket blocked the vent hole.
I think it sat wrong, one lip is wider.
« Last Edit: May 02, 2023, 05:27:25 AM by PeWe »
Offline Kenzo1979
« Reply #6 on: May 02, 2023, 05:51:01 AM »
Low fuel?  Too low?  Petcock on reserve?  Petcock clean and working properly?  Pics of this “new locking gas cap”?
--Kenzo
** 71 CB500, 74 CB550, 76 CB400F, 77 CJ360t **
« Reply #7 on: May 02, 2023, 06:16:07 AM »
I had to drill a 1/16th hole through the F1 tank cap
 That was for a high flow Pingel petcock
Online Stev-o
« Reply #8 on: May 02, 2023, 06:37:57 AM »
The fuel system is gravity fed, need a vented cap!
