Author Topic: Compatibility of crank case between models…must rebuild by may 28th!!!!  (Read 551 times)
Offline matchstikman
  • ask the toecutter! he knows who I am!
Well……I have a 1976 cb750 f1 super sport with a quarter size hole punched through under the drive gear. Upper and lower cases damaged. So are the k and F model cases the same? I’m using all the gears and bearings from the old engine because they’re immaculate. I found a nice one on eBay and it says it’s pulled from a K bike
Thanks in advanced for your input
Stone (1974) Greatest biker movie ever made!
Online willbird
Back in the day the shade tree folks fixed that with JB weld and kept riding. In the early 70's the 750K needed a riveted together chain, friend of my dad insisted on using industrial chain he got from work and broke a chain and case. JB weld to the rescue. I have heard of other folks doing the same.
It would be nice to continue using the original case. I think I just might. Thanks for your input bud!
Offline Ellz10
  • ZZ
  • Knowledge is Power
I would not use JB Weld as suggested. I would have it welded properly. If the cases are fully torn down, then welding it is easiest and best. TIG or MIG works fine. Then you can reuse the stock components and abandon any swap “issues”.
+1
Thankful for everyone on this forum. Grateful to continue to learn so much.
'77 K7 - http://forums.sohc4.net/index.php/topic,193043.msg2251436/topicseen.html#new
 I may have a solution, PM sent.
