Happily, today I got the bike in good enough shape for a quick shakedown run.
I had some iffy stuff happen yesterday, so this was less a proper ride and more double checking a few problem areas.  My oil light was on the fritz (coming on when I revved it, but on when it was at idle), so thankfully that went away.  I was chasing fuel leaks at the petcock, but a couple spare clips solved that.  I also wanted to check for oil leaks, and thankfully I did NOT find anything there.
Actual performance was quite nice.  I swapped out my rock-hard Chinese replica rear shocks for a pair of still-Chinese Tec shocks, but they at least had the correct spring rating, the ride was quite pleasant.  Combine that with a crank balance, and this bike has never been smoother.  Power delivery it also smooth with no hesitation, so all good things there.
The only downside is that when the bike is hot it tends to idle down and eventually die.  A quick search points to an overly-rich idle setting, and at least one of the plugs I could get to seemed pretty black and fluffy.  This is odd, because I was able to get a rock-solid idle while I was doing my carb sync, but I guess on the road is a different animal.  Still, looks like an idle-drop is in my future.
