If you click on the kit on the web site it tells you what size to drill and tap, 10mm i think. Personaly. I would want to split the cases as its in a very awkward place but if you can get straight on it drilling carefully with well greased drills and greasing the tap should keep most of the swarf out of the cases and being alloy small bits should not hurt
