After going through the obvious stuff like jets, float height, mixture and choke, my first thought is that you have a vacuum leak. Can you check for that before proceeding?
Next, would be to check the cable play at the carbs. This is not scientific, but it gives you a clue to where the problem could be. When the throttle is at zero and the bike is off, there should be about the same about of play in each cable at each carb (a few mm). Lift the cable of each carb inside the brass adjuster and stop before you begin to raise the slide. If you find that all of the have about the same amount of play except for #1, the you have a issue with your brass cable adjuster on the #1 carb. Your idle sounds ok, but thats at zero throttle. As you advance the throttle and the slides move up, they need to move at the exact same rate (assume all else is equal). If one of them is off because of cable play, then the slide would raise later or earlier than the others. A common problem is to switch cables on the 1&2 or 3&4 carbs after remounting them. This can cause cable adjustment to be way off. Make sure the two slightly longer of the four ends are going to 1 and 4.
After years wrestling with K0 and K1-6 carbs, I much prefer the K0 carbs. Perhaps I'm nuts
