Author Topic: Dad's 1978 Honda CB550k  (Read 73621 times)
Offline joegeis
  • '78 Honda CB550k
    • Photo Album
Re: Dad's 1978 Honda CB550k
« Reply #300 on: September 25, 2023, 06:10:32 AM »
This could be it then.  I never did that maintenance task! It would be amazing if this solved my idle issue!
« Reply #301 on: September 25, 2023, 06:31:33 AM »
Might be. “Varnish” builds up on the centre shaft, which makes the return slow or sticky as the revs drop. A simple check is to just grab the cam and manually twist it (engine off!). It should rotate a few degrees and go back freely.
To clean it up, you will have to remove the points plate and then do points gap and ignition timing again….. have you checked ignition timing with a strobe light? You also want to make sure you have it spot on for total advance. Too much advance can also slow the return to idle.
« Last Edit: September 25, 2023, 06:34:13 AM by BenelliSEI »
Online newday777
« Reply #302 on: September 25, 2023, 07:23:58 AM »
Do you have a strobe timing light? You need to test the advancer with a timing light to see if the advancer is working properly. Full advance at 2,800-3,000 rpm. Before that and you know that you will need to clean it up, and possibly cut the springs.
Offline joegeis
  • '78 Honda CB550k
    • Photo Album
« Reply #303 on: September 25, 2023, 10:19:00 AM »
I had set timing with my test light, not a strobe.
God love CMC. They have a video for everything! I'll follow this video later this week. Is there a way to tell if it is "out of spec" once removed? Or do I need to clean, reinstall and set timing to determine if this is my problem? If it is, do I just replace the springs?
https://www.youtube.com/watch?v=NWmeU3OALfU
« Last Edit: September 25, 2023, 10:31:43 AM by joegeis »
Online newday777
« Reply #304 on: September 25, 2023, 11:27:21 AM »
Yes with a strobe timing light
Offline joegeis
  • '78 Honda CB550k
    • Photo Album
« Reply #305 on: September 25, 2023, 12:23:35 PM »
okay, well I'll have to procure a strobe timing light if that is necessary. I did already disassemble, clean, lube and reassemble the advancer and verify timing with my test light (no adjustment was needed - I marked plate location with a sharpie before taking it off). Everything looked to be in pretty good condition. Very minimal corrosion but the grease was all dried up and sticky.
Quick test shows some improvement. Cold start idle was quite a bit more even, with less idle screw adjustment. After running 1 minute at a steady 1600 rpm, after revving to 3000 rpm, it would come back down to 1600, albeit pretty slowly. This is an improvement over previous where it would hang and 3000 until I messed with the idle screw very often. Granted this was all of 10 minutes of testing. I'll evaluate more the next time I take the bike out.
Would replacing my advancer springs result in the idle coming back down more quickly?
quick google search results: Would this work for strobe timing?
Edit - found a video on setting strobe timing. CMC of course :)
« Last Edit: September 25, 2023, 12:44:07 PM by joegeis »
Online newday777
« Reply #306 on: September 25, 2023, 12:51:49 PM »
Yes that timing light will work.
Again check with the timing light to know if the advancer is working properly.
« Reply #307 on: September 25, 2023, 01:53:37 PM »
How snug do both your advancer springs feel before you twist the advancer ?
« Reply #308 on: September 25, 2023, 06:41:32 PM »
Replacement of springs may not be needed. Removing loop and reforming end is usually enough. I think Yamiya has replacement springs if you are ordering things from them you could add them to your order. If you need to reform them you can decide after you have ran them for a while if you need to replace them.
Air leaks can cause idle to stay up and not decay right away too. But you have ruled that out.
Be methodical and don't change a bunch of things at once lest you never know what caused your issue or if you introduced something else...
It is nice that you can run the bike without the points cover for testing purposes...
Offline joegeis
  • '78 Honda CB550k
    • Photo Album
« Reply #309 on: September 25, 2023, 08:18:34 PM »
I had to pull the spring 1-2mm in order to stretch it over the post, so it's not loose. I ordered the strobe light,  so I can test that later this week.
With all new intake rubber,  I would be shocked if there was an air leak.
« Reply #310 on: September 26, 2023, 07:28:29 PM »
Offline joegeis
  • '78 Honda CB550k
    • Photo Album
« Reply #311 on: September 29, 2023, 09:48:10 AM »
Strobe light arrived and I'm looking at the dynamic timing. Here is a video. I let the bike run for a couple of minutes. It was holding a steady 1200 rpms without the idle wandering. I'm having a hard time telling if the timing is good or not. The F line is bouncing back and forth, and I'm not sure what "right" looks like. Is this just the way it looks, or is something else off causing it to bounce around?
https://photos.app.goo.gl/5YCxfbZhQrvTs3PW7
It's not in the video, but I tried this at 3000 rpm to see if it would smooth out, but it just bounces faster. Is this a symptom of loose springs?
« Last Edit: September 29, 2023, 09:52:03 AM by joegeis »
Offline joegeis
  • '78 Honda CB550k
    • Photo Album
« Reply #312 on: September 29, 2023, 12:03:31 PM »
Had it steady at 3000 rpm and it was bouncing the same amount,  but faster. Should I cut half a turn of each spring and try again?
« Reply #313 on: September 29, 2023, 12:13:11 PM »
Are you saying the F mark is bouncing around the fixed point? If that is so, then the springs are weak and a 1/2 loop might help. Do as little as possible and see if there is an improvement…..,
Offline joegeis
  • '78 Honda CB550k
    • Photo Album
« Reply #314 on: September 29, 2023, 12:27:56 PM »
Watch the video in the link I posted and you can see exactly what I mean
« Reply #315 on: September 29, 2023, 01:42:30 PM »
take the inductve clamp of your light  and clip it the other way.  Also sometimes helps to power the strobe from a battery seperate from the bike
« Reply #316 on: September 29, 2023, 02:05:06 PM »
Sorry….. video is not clear enough….
Offline joegeis
  • '78 Honda CB550k
    • Photo Album
« Reply #317 on: September 29, 2023, 02:58:02 PM »
Yes, the F mark is "bouncing" around the fixed mark. The fixed mark is stationary.
When I flip the induction clip, it does not strobe at all. I'll try attaching to a different battery. Assuming that doesn't change anything, I'll cut half a turn off each spring and test again.
Offline joegeis
  • '78 Honda CB550k
    • Photo Album
« Reply #318 on: September 29, 2023, 04:22:25 PM »
Okay, I shortened the springs a half a turn. I immediately noticed that the engine would come back to idle speed after revving MUCH more quickly. The throttle would not float around 3000 rpms as it would before, even when cold.
At ~1200 rpms, the T F marks continued to look like they "bounced" around quite a bit. However, at 2000 rpms, they definitely smoothed out. I managed to capture pictures rather than a video that give a good indication of what the readings look like. To be honest, I truly do not understand ignition timing, and what all this is actually doing, so I'm not sure if this is good or not. This is with no changes from where I had static timing set.
Fairly steady timing at 2,000 RPM:
Going to take it for a test ride to see how it feels and if the rpms hang anymore.
« Reply #319 on: September 29, 2023, 08:22:55 PM »
Let’s start from scratch. Your timing light is hooked up to a battery and the induction lead (the one sensing the spark pulse and making the light flash) is clamped to the #1 spark plug cable. What you are trying to achieve is full detonation of the charge (air/fuel mixture) with the piston at the top of its stroke (TDC Top Dead Centre). At idle, the spark fires only a few degrees before the piston reaches TDC to achieve this. At over 2500 rpm things are happening so fast that the weights on the advancer are rotating the points cam ahead, setting the spark to fire almost 30 degrees before the piston reaches TDC in order to get the “bang” at the right time. Make any sense?? Read the attached photo from the factory manual.
At idle, you should see the F 1.4 mark appearing to align with the fixed mark on the case. Your first picture above, looks like what you should see at idle, not at 2000 rpm. If that is the case you need to advance the timing by rotating the points plate counter clockwise until you see that F 1.4 mark line up at 1000 rpm.
Staying with the #1 cylinder, now rev it up and see if you hit the total advance marks line up. They are two stamped lines to the right of the F1.4 mark that should come into view as you rev it up. They should straddle the fixed mark. Take pictures at idle and +2500 rpm and show us what you see.
You’re getting close. When you get this right, your bike will run MUCH better.
« Last Edit: September 29, 2023, 08:53:30 PM by BenelliSEI »
Offline joegeis
  • '78 Honda CB550k
    • Photo Album
« Reply #320 on: September 29, 2023, 09:13:56 PM »
Thanks Benelli, that helps!
So, a couple things then,
1. Even though I cut the springs and they are definitely providing more resistance, I still had inconsistent readings at idle speed (I was at 1,600 rpms, not 1,000). Seems that the lower the rpm, the more "bouncy" and illegible the readings are for me, still.
2. Assuming the issue in #1 is resolved, at 1,000 rpm, I should see the line immediately to the left of F 1.4 line up with the fixed mark on the case, and at 2,500+ rpm, the F1.4 will should be to the LEFT of the case mark. (If I am understanding, the advancer spins clockwise, which means that the firing is happening sooner?)
3. For some reason, at higher rpm the reading is very stable and clear, and does not "bounce" anymore since shortening the springs.
Tomorrow I will start over and will gap the points again, set static timing again and then grab more pictures (or videos if its bouncy) at 1,000 and 2,500 rpm.
Thanks!
« Reply #321 on: September 30, 2023, 05:01:14 AM »
2. Careful here. The T mark is TDC. The F1.4 is just to the RIGHT and is advance at idle. The marks for FULL advance at 2500-3000 RPM are even farther to the RIGHT.
Online MauiK3
« Reply #322 on: September 30, 2023, 07:58:54 AM »
Not sure if this has been discussed.
The induction timing lights often have an arrow indicating which way they clamp to the plug wire. The arrow points to the plug.
« Reply #323 on: September 30, 2023, 08:45:59 AM »
True! Mine also is pretty sporadic at idle and strobes more consistently at higher revs. I used to have a 3” piece of stiff, tightly wound spring that snapped onto the plug and then the plug cap snapped to the top of it. When you clipped the clamp around the spring, the light worked 100X better. I put a short piece of shrink wrap around it and it worked well on SOHC motors……  it bounced off into never-never land a few years ago (never to be seen again)!
Offline denward17
« Reply #324 on: September 30, 2023, 08:46:24 AM »
I don't know 550 bikes that well....
Could it be from a bent shaft on the end?  see this thread....
http://forums.sohc4.net/index.php/topic,193574.0.html
