Author Topic: Front wheel moves L to R on axel  (Read 563 times)
Offline JDrider
  • Slowly becoming an uncertified cb550 mechanic
« on: May 27, 2023, 06:56:21 AM »
1975 cb550k1
My front brake has always been spongy.
Rebuilt the brake system and still the same.
I noticed the wheel can move left to right 2mm or so.
And I’m sure it’s not supposed to do that.
I imagine it would cause the brakes to not work properly.
So how can this be remedied?
Is there a shim or spacer missing or is it bearings?
Pics attached of the movement difference.
Thanks,
JD
1975 CB550K1
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Front wheel moves L to R on axel
« Reply #1 on: May 27, 2023, 07:51:13 AM »
https://www.cmsnl.com/honda-cb550-four-cb550k3-1977-usa_model1015/partslist/F++09.html
Here is a parts diagram.
Looks like you have a collar in there. Check your assembly against the diagram
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #2 on: May 27, 2023, 08:12:13 AM »
The axle nuts on backwards, hexagon should be next to wheel not outside fork slider
Offline JDrider
« Reply #3 on: May 27, 2023, 08:40:41 AM »
So you think the backwards nut will fix my situation?
I’m glad you noticed that.
JD
1975 CB550K1
« Reply #4 on: May 27, 2023, 08:59:21 AM »
99.99% certain, as it is its not holding anything together, right way round clamps everything on axle tight, make sure speedo drive is engaged in tangs before tightening!
Offline JDrider
« Reply #5 on: May 27, 2023, 09:09:53 AM »
Thank you guys for your help.
I have never messed with a wheel removal before.
I will look into this
JD
1975 CB550K1
Offline BenelliSEI
  • 1969 cb750
« Reply #6 on: May 27, 2023, 11:03:53 AM »
Do it sooner than later. That play will “knock back” the pad and cylinder in your caliper, resulting in a very long lever, before anything actually happens.
Offline JDrider
« Reply #7 on: May 27, 2023, 11:07:40 AM »
That is exactly the problem.
Do need to remove the wheel from the forks to do this?
JD
1975 CB550K1
« Reply #8 on: May 27, 2023, 11:14:32 AM »
Yes, you need to remove wheel, put a bar in the hole on other end of axle, undo nut, turn over so hex is by wheel and do up tight making sure speedo drive is engaged and working all the time you are tightening.
3 hands helps but 2 will do
Offline JDrider
« Reply #9 on: May 27, 2023, 11:16:24 AM »
Thank you
JD
1975 CB550K1
« Reply #10 on: May 27, 2023, 12:01:26 PM »
 The axle caps also have a gap at the rear that is normal, you can see the difference when looking at the cap.
« Reply #11 on: May 27, 2023, 12:19:06 PM »
There should also be an arrow that faces forwads
Offline JDrider
« Reply #12 on: May 28, 2023, 07:57:29 AM »
So …
When I went to remove the Speedo cable, it was already stripped.
So that took longest.
After that, had my dad sit on the rear seat and got everything removed
And reversed the axel nut and put back together.
Thanks for the help. Now I have to find a new Speedo screw. I put the old one in finger tight.
JD
1975 CB550K1
Offline Scootch
  • Someday I'll know what I needed to know years ago
« Reply #13 on: May 28, 2023, 08:31:04 AM »
Dad looks like a natural !  Perhaps he needs a bike?  🙂
Offline CycleRanger
  • No comment about being an
« Reply #14 on: May 28, 2023, 09:18:45 AM »
Yes! Like this.
« Reply #15 on: May 28, 2023, 09:29:58 AM »
 That bulletin is a perfect illustration.  Those speedometer cable screws are usually a pain for me too.
Offline CycleRanger
« Reply #16 on: May 28, 2023, 09:35:42 AM »
Here's the other bulletin about the front axle.
« Reply #17 on: May 28, 2023, 09:51:22 AM »
The speedo cable screw is called an "oval" screw and either 5 or 6 mm thread so doesnt have to be Honda.
Oval by the way means convex front and back of head
« Reply #18 on: May 28, 2023, 10:44:41 AM »
Take your old screw to Ace Hardware, they have the correct metric screw for that in all of the Aces around here.
« Reply #19 on: May 28, 2023, 10:48:53 AM »
 The axle from the wrong side bulletin may solve a few mystery brake issues we've seen here.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #20 on: May 29, 2023, 02:28:31 PM »
Always good to have a good shop manual and a good set of parts diagrams.
1973 CB 750 K3
