Author Topic: Hard clutch pull (Fixed)  (Read 1681 times)
Offline JDrider
  • Slowly becoming an uncertified cb550 mechanic
Re: Hard clutch pull (Fixed)
« Reply #25 on: June 04, 2023, 04:30:00 AM »
So this morning I decided to remove the “new” cable the previous owner
Installed and replaced with a new Honda cable.
The clutch is now smooth and pulls perfect.
Thanks Stu and everyone for your help!
JD
1975 CB550K1
Offline stocky
« Reply #26 on: June 04, 2023, 08:10:58 AM »
Had a very similar issue with a new aftermarket throttle cable that was very stiff even after lube. Ended up snapping after a year. Replaced with a new OEM cable and the difference it made was so much smoother and better, felt like a different bike. Keep those cables OEM.
Offline JDrider
« Reply #27 on: June 04, 2023, 09:15:03 AM »
I took the bike for a ride today, and man does it feel like a whole new bike!
It’s shifts so smoothly, and I can find neutral immediately.
This is so great. I appreciate all the help on this forum from everybody.
« Last Edit: June 04, 2023, 09:17:15 AM by JDrider »
JD
1975 CB550K1
« Reply #28 on: June 04, 2023, 09:50:01 AM »
I fully understand your feelings! ;)
That and smooth running engine from idle and up make it fun to ride.
