Author Topic: Battery Install  (Read 540 times)
Offline BenelliSEI
  • 1969 cb750
Battery Install
« on: June 05, 2023, 06:46:42 AM »
Put a new battery in the K3 today. Little trick to stop the terminal nut from falling out and disappearing? 1/2 an earplug, stuffed under the nut…..
Re: Battery Install
« Reply #1 on: June 05, 2023, 07:26:27 AM »
Good idea!
No need to use the magnet on the flexible arm then! ;D
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Battery Install
« Reply #2 on: June 05, 2023, 07:53:36 AM »
Pure genius
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline BenelliSEI
  • 1969 cb750
Re: Battery Install
« Reply #3 on: June 05, 2023, 08:27:30 AM »
Too many have “disappeared”!
Re: Battery Install
« Reply #4 on: June 05, 2023, 08:42:00 AM »
I've always used a little piece of rubber tubing under the nut. Very frustrating losing one 'in there' and also keeps it lined up nicely.
Offline Kevin D
  • SE Michigan
Re: Battery Install
« Reply #5 on: June 05, 2023, 09:05:56 AM »
Used to be the bolts were sized to pick up the nut and not punch a hole in the battery either.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline robvangulik
  • Honda Fourever
Re: Battery Install
« Reply #6 on: June 05, 2023, 09:22:20 AM »
I've been using (the same)pieces of transparant tubing that came with a battery for at least 2 decades ;D
