Author Topic: Drive hub stuck  (Read 1471 times)
Offline Gurp
  • I'm no.......
  • Once was a...
Drive hub stuck
« on: June 16, 2023, 03:26:28 PM »
How are you guys getting this off. Mine is old and chewed up and I cannot get it to hardly move.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Re: Drive hub stuck
« Reply #1 on: June 16, 2023, 03:36:20 PM »
Or are you asking about the bearing retainer in the center of the drive hub??
As to the hub, it is sticking to the rubber dampers. Spray in some silicone to help lube the rubber to aluminum posts.
I usually leave the sprocket on to use as a lever point.
« Last Edit: June 16, 2023, 03:39:54 PM by newday777 »
Offline Gurp
  • I'm no.......
  • Once was a...
Re: Drive hub stuck
« Reply #2 on: June 16, 2023, 03:52:10 PM »
The retainer. I am having zero luck with it. It's turned little with a punch and hammer now it won't move.
Re: Drive hub stuck
« Reply #3 on: June 16, 2023, 05:58:28 PM »
I'm guessing by the looks of the picture you didn't drill out the staking punches before turning it? 🤔
Re: Drive hub stuck
« Reply #4 on: June 16, 2023, 06:03:33 PM »
Re: Drive hub stuck
« Reply #5 on: June 16, 2023, 06:35:49 PM »
100% guaranteed they were not. And once you do drill them out, you may likely need some LOTS OF heat to release that retainer from the threads.
;D
Offline CycleRanger
  • No comment about being an
Re: Drive hub stuck
« Reply #6 on: June 16, 2023, 06:50:35 PM »
And that retainer is also reverse threaded.
« Last Edit: June 20, 2023, 07:01:16 AM by CycleRanger »
Offline Gurp
  • I'm no.......
  • Once was a...
Re: Drive hub stuck
« Reply #7 on: June 16, 2023, 07:54:48 PM »
I ended up getting it. It was the reverse thread part that was getting me. Lol
Maybe a lack of sleep as well but mostly reverse thread.
Re: Drive hub stuck
« Reply #8 on: June 17, 2023, 05:24:14 AM »
I’ve also found that since I bought the right tool, I haven’t messed any up, and been able to reuse them. I bought it on EBay (came from England!. 4 pins, 3/8” drive. I mount it up in my rechargeable impact gun (small), stand over the wheel (so I can push down annd keep it engaged 100%) and give it a few short blasts (after drilling). Spin right out.
Re: Drive hub stuck
« Reply #9 on: June 17, 2023, 07:57:08 AM »
Sounds like a great tool!
Offline CycleRanger
Re: Drive hub stuck
« Reply #10 on: June 17, 2023, 08:26:13 AM »
If you're going to do a bunch of these a pin spanner is also a good investment.
Something like this:
https://www.amazon.com/Variable-Cylinder-Spanner-Wrench-Adjustable/dp/B09D2XD2B4
Offline Gurp
  • I'm no.......
  • Once was a...
Re: Drive hub stuck
« Reply #11 on: June 17, 2023, 09:16:00 AM »
Do you have a link to the type you bought?
Re: Drive hub stuck
« Reply #12 on: June 17, 2023, 02:16:11 PM »
Try Honda-classics.co.uk they do all the special tools plus stainless caliper pistons etc
Re: Drive hub stuck
« Reply #13 on: June 19, 2023, 06:16:31 PM »
Sorry…. Missed the question. I believe that is where I bought a very nice set. I’ll pull them out tomorrow and add a few pics
Offline Alan F.
Re: Drive hub stuck
« Reply #14 on: June 20, 2023, 06:03:45 AM »
Reverse thread, I'll have to make a note of that.
I guess Honda Engineers couldn't trust staking the threads  to keep the retainer in place?
Is this only so on 500/550 or other models too?
Re: Drive hub stuck
« Reply #15 on: June 21, 2023, 02:42:11 PM »
 I don't remember a 750 being left hand threads, but I'm pretty old and drank a few beers since the last one I took apart.
Re: Drive hub stuck
« Reply #16 on: June 21, 2023, 02:56:29 PM »
My K3 750 was not reverse thread as I recall, it was pretty tough to remove and install in spite of the threads looking fine.
