Author Topic: 74 CB550K Speedo  (Read 828 times)
Offline Sdsbassist
  • Gus, Austin, MN.
74 CB550K Speedo
« on: June 16, 2023, 07:07:47 PM »
Speedometer question.
I have a 74 550k.
The speedo dial is slow, for lack of a better term. Takes a long time to get up to speed, then a long time to go back down again. Been sitting for 15 years.
Changed tach and speedo cable, same issue.
I was curious if this will work itself out.
Otherwise, I have this speedo set from either a later model K or possible a 500 twin. (See photo below)
The mounting holes are the same and these are in MUCH better shape. Can they be swapped out and still give accurate mph?
Sent from my SM-N960U using Tapatalk
« Last Edit: June 16, 2023, 07:10:08 PM by Sdsbassist »
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline flatlander
Re: 74 CB550K Speedo
« Reply #1 on: June 16, 2023, 11:27:45 PM »
500 and 550 speedos (thinking of those swimming pants now  :o) have the same gear ration so yes, they can be interchanged.
it might be that it sort itself out, though. you could just mount it and drive around with it for a while to see what happens. i bought once an original old speedo (not the swim pants) for my 550. it was one that was brand new and had been sitting on the shelf in an old shop for decades. was also a bit slow at first but sorted itself out and works fine now.
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: June 17, 2023, 05:18:11 AM »
+1 to above….. I’ve had a few sort themselves.
