Author Topic: Gear whine  (Read 472 times)
Offline Kasindy
Gear whine
« on: June 24, 2023, 07:11:49 AM »
My 1973 CB 350F with stock exhaust has what I would consider an annoying gear whine.  It occurs in every gear  when the clutch is engaged.  When I put the bike up on the center stand and run it in first gear, it will only whine when I slightly apply the brake.   What is normal?  I have a CB 350G that is much quieter.
Offline newday777
Re: Gear whine
« Reply #1 on: June 24, 2023, 08:30:29 AM »
Have you pulled the rear wheel and put a finger in the bearings to inspect them for notches? Bad bearings can give a whine.
Stu
My current rides
Prior bikes....
