Support the site. Your contributions keep this site running.
Rubber band trick is good not bad, you use to hold theadjuster ends of the rocker arms up by connecting the arms on each cylinder with them
Have you messed with your exhaust at all?Sent from my SM-N960U using Tapatalk
Presuming you have already adjusted the cam chain and checked your valve clearances from earlier post about the later...
