« Reply #21 on: July 09, 2023, 11:10:47 PM »
One thing, when starting, choke only used to start. If left on after, it dies.
That is how it should be, fire it up with choke on, once started move lever down to off as needed and slowly blip the throttle a little bit to keep it running until warm enough to atomize the fuel properly on it's own at idle.
I don't let mine set idling more than a minute unless it's below 70°(to fully warm up before riding) I start off slowly as I have a long driveway and then a short distance on the road to a stop sign, then once on the main road, speed limit through town is 30 so I can take my time warming it up for a mile going easy.
« Last Edit: July 09, 2023, 11:12:49 PM by newday777 »
![](http://forums.sohc4.net/Themes/default/images/ip.gif)
Logged
