Alright, y'all, I need help. I am at my wits end with this. I think I am having a carb tuning issue.
1972 CB500k
Stock Airbox with new filter
Set points gap and points, gets 12v right at the F marks.
Set valve clearance to spec, rotated engine to confirm.
Synced carbs, they are all reading roughly the same (300mm ish?)
Completely clean carbs, new jets and o-rings
Set float height to spec
New Reg/rec and am battery is staying at 12.7v between runs
Battery reads about 13.2v at 3k rpm
Throttle tube has about 1/8 inch of play before engaging the throttle body
I have experimented with all sorts of variations on air mix screw, from all the way in to all the way out. Bike runs best with them almost all the way out.
4 into 1 exhaust
Jets are 100 and 38
Checked for leaks around intake with spraying some fluid
After all this I pulled the spark plugs and they look fine (tan, no oil or gas)
Runs great at higher RPM (I can get it to red line and I feel like it has a good amount of power)
THE ISSUE:
Bike will start and idle great at 2k rpm indefinitely. However, when I blip the throttle it'll spike up to 3-4k rpm, then slowly climb back down. If I decrease the idle screw to below 2k rpm, it'll slowly bog down and die. Any Ideas?
I am thinking I want to pull the carbs and check the idle air circuit to make sure there are no blockages.
