Author Topic: Small nail in rear tire, should I patch tire?  (Read 451 times)
Offline denward17
« on: July 11, 2023, 03:54:21 PM »
Went for a ride today and after a few miles it began to feel odd, so decided to make it short and went home.
Rear tire pressure was about 12-15 psi.
Found a small nail.  I am ordering a new tube, but with a nail this small, do I need to patch the inside of tire?
Offline BenelliSEI
  • 1969 cb750
Re: Small nail in rear tire, should I patch tire?
« Reply #1 on: July 11, 2023, 03:58:16 PM »
I’ll be interested to hear what others say, but I’d make sure the rubber is nice and smooth on the inside and install the new tube. I seriously doubt it needs anything else!
Offline pjlogue
« Reply #2 on: July 11, 2023, 04:35:04 PM »
I would put a new innertube in and you should be good to go.  Only time you need to patch the tire would be for tubeless.
-P.
« Reply #3 on: July 11, 2023, 04:37:37 PM »
If you were going to ride bike in wet weather it would keep moisture out of the tire/rim to patch the tire too. That's the only advantage or reason to do it imho
Offline denward17
« Reply #4 on: July 11, 2023, 04:41:28 PM »
Thanks Guys, no riding in wet weather for me.
« Reply #5 on: July 11, 2023, 05:01:12 PM »
I would not patch it with a new tube. If you patch it the tire has to come off completely and if its just a new tube then only one side. Gotta make sure all the steel comes out though.
« Reply #6 on: July 12, 2023, 12:05:15 AM »
Make sure there are no raised bits arround the hole which might rub the tube
