Well...one of the things I learned when I worked building automated assembly equipment for companies like Gates Energy (now Enersys) and some other battery makers whom I can't name was: up until 2010, only Japan in the Far East made batteries with virgin purified lead (Yuasa was mentioned).
The telecom equipment I used to work with was all powered with 48VDC, with battery back-up. The standard was to have 8 hours worth of battery power in the event of a power outage, with larger offices having back-up generators to provide for extended outages. (Did anyone ever notice that even when the lights were out, the landline phone still worked?
In the late '80s, we had a lot of small, cabinet mounted remote systems, that had a capacity of 640 telephone lines, connected to the host office with T1 transmission lines. The cabinets were about 8 feet wide by 2 1/2 feet deep by 6 foot high, and included 6 strings of 4x12V, 25 amp-hour batteries in series to achieve the desired 8 hour capacity.
One of these remotes, which had only been in service for about a year, experienced a power outage, and the batteries failed after only one hour!! The vendor had started using Yuasa batteries, instead of the Gates Cyclon batteries they had used before, some of which had also suffered an early death, but never as early as the Yuasa. I was assigned to determine the cause, and found the temperatures inside the dark brown cabinets sitting in the desert sun to be a major factor. During my research, I did a load test on a new set of batteries on a remote that was being relocated, and was told to dispose of the Gates Cyclon batteries that had been replaced out of an abundance of caution. I "disposed" of them at my solar powered cabin, where they served me well for another 5 years.
