Author Topic: Raise your hand if you have ever seen one?????  (Read 627 times)
Offline britman
« on: August 04, 2023, 12:24:49 PM »
I had not, a vintage oil cooler from who knows what year.  The base goes to the the oil filter via an adapter.  Was on my ugly, cut frame, rear Harley wheel, extended forks, Ray Charles installed wiring harness, every bolt frozen, missing parts, project bike......
Offline jlh3rd
Re: Raise your hand if you have ever seen one?????
« Reply #1 on: August 04, 2023, 01:06:09 PM »
yeah...they were around back in the day....I wanted one for the '76 550 I had. Installed one for my '03 electra-glide I had.
« Last Edit: August 04, 2023, 01:07:54 PM by jlh3rd »
« Reply #2 on: August 04, 2023, 02:26:14 PM »
I can’t imagine they look very good installed
Offline WideAWAKE
« Reply #3 on: August 04, 2023, 02:41:17 PM »
Had one on my K0 when I bought it.
First thing to get chucked into the bin.
« Reply #4 on: August 04, 2023, 04:05:50 PM »
Might be finding some internal engine go fast mods that often require oil cooling if the bike is gonna be rode hard in hot weather for several miles at a time.  If you ever rode a big bore on a hot summer day, you will certainly notice there is some extra heat that wants out of that engine.
Those look like nice parts to me, minus that sketchy clear tubeing.  If you use those definitely get some better oil hose.
« Last Edit: August 04, 2023, 04:07:47 PM by seanbarney41 »
« Reply #5 on: August 04, 2023, 04:09:36 PM »
Certainly not when all these bikes are meant to do is look good on display and putt putting to the nearest grocery.(sic)
« Reply #6 on: August 04, 2023, 04:22:02 PM »
 Somewhere I have an adapter with a thermostatic valve in it. My Rat Race bike has a Lockheart that was ruined with chrome plating of the frame but there is a better original one on its brother bike.
« Reply #7 on: August 04, 2023, 06:00:32 PM »
Wasn't the Lockhart the first one (or maybe ONLY one) to have that thermostatic bypass for the cold engine? That was a fave feature on the racers I worked with. I've never installed one (removed quite a few), and I think I've seen some 5 different brands of them. My fave, though, was on a roadracer: it was a Ford power-steering oil cooler, mounted into the oil feed hose, mounted behind the right (rearset) footpeg where the airflow from the fairing exited from the engine. It both warmed (when cold) and cooled (when hot at speed) the oil enroute to the engine, and was [almost] free at the local junkyard. :)
« Reply #8 on: August 04, 2023, 06:48:54 PM »
Sounds cool!
« Reply #9 on: August 04, 2023, 06:57:40 PM »
I remember the Derale oil coolers having the thermostat option….
Haven’t heard LockHart in years….
« Reply #10 on: August 04, 2023, 08:40:45 PM »
I like the design of the Derale oil coolers;very efficient.
