Author Topic: Replacement "E-Z" type idle mixture screw for Keihin PD46  (Read 607 times)
Offline deeveebee
« on: August 08, 2023, 07:03:01 AM »
I find adjusting the mixture screws on my '78 550K to be unnecessarily fiddly -- especially the one for cylinder 2.  Is there a compelling reason (other than aesthetics) NOT to replace the oem screws with a longer, thumb-type adjuster screw?  Does a high-quality one even exist for these carbs?  I found something like this after a half-assed search but I'm wary:
https://www.ebay.com/itm/363831200874?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=LEFzai6xSqu&sssrc=2047675&ssuid=b0bw8nRdS4q&widget_ver=artemis&media=COPY
Assuming I should stick with oem, what tool have people found that makes this job a little easier -- is there a good, low-slop, right-angle screwdriver that would work?
Thanks as always.
Online denward17
Re: Replacement "E-Z" type idle mixture screw for Keihin PD46
« Reply #1 on: August 08, 2023, 07:13:41 AM »
That's brilliant....if it works....
If the taper can be guaranteed to work, I don't see a problem.
It is a pain to adjust #2, I bought a snubby screw driver.
https://www.amazon.com/dp/B085CS9B8V?psc=1&ref=ppx_pop_dt_b_product_details
« Reply #2 on: August 08, 2023, 07:31:57 AM »
I have serious doubts that the ebay offering will work correctly.  I made a right angle tool from a slot car axle, ring and pinion gear set.  Just ground the axle end to a straight  slot tip.
But, a short driver bit and oven gloves can work, too.
If you are tool collector…
 https://www.ebay.com/itm/171178936621?chn=ps&norover=1&mkevt=1&mkrid=711-213727-13078-0&mkcid=2&itemid=171178936621&targetid=4580153136941822&device=c&mktype=&googleloc=&poi=&campaignid=437225723&mkgroupid=1224856224320864&rlsatarget=pla-4580153136941822&abcId=9300907&merchantid=51291&msclkid=c7a70e1ee4c21b3162426accb58cd48b
Offline deeveebee
« Reply #3 on: August 08, 2023, 07:52:34 AM »
If that were only about half the price . . .
Offline fizzlebottom
« Reply #4 on: August 08, 2023, 08:08:04 AM »
I've seen these and thought about getting a set just to have an easier time adjusting on the fly when I'm fine-tuning, or if I take a trip over the mountains. I even have the Motion Pro tool, but it is so long I can't even put it in my tank bag.
Until someone (not me) can confirm that they're actually correctly made though, I'm not going to throw them in my carbs. I fiddle with that adjustment so rarely that these screws wouldn't really make my life easier enough to justify the purchase.
1982 CB650SC Nighthawk
2024 Kawasaki Z900RS
« Reply #5 on: August 08, 2023, 09:00:26 AM »
That was why I made my own version with parts I had laying around.    But, if you can make one for less than $30 time and materials, you might have a lucrative offering for sales!
Offline enwri
  • So that noise is normal?
« Reply #6 on: August 11, 2023, 05:23:14 AM »
Bit late and not the same carbs, but anyway, others might be similar.
In the K7 PD41A BPG^ (Australian?) carbs the screws have a bit sticking out about a 1/4 inch.
Stuck old overflow hose over them cut on an angle so I could count turns easier.
2-3 are a little longer to make it a little easier to reach.
Edit.   How did I make that bold text? doesn't matter.
It was square brackets around the B fixed it no more bold
« Last Edit: August 11, 2023, 05:33:30 AM by enwri »
77 CB 750 k.. 29 years and counting.
91 TDM 850 (No.34) so comfy and soft
8? XJ 550 meh...
76 XL 350 Super Sport stump puller..
80 XR 200 idiot proof
75 MX 250 b dangerous
