Author Topic: Camshaft  (Read 601 times)
Offline KemuelD2006
    • Don’t have
Camshaft
« on: August 10, 2023, 03:39:36 PM »
Will a earlier cam work in the later 77/78 models
Online newday777
Re: Camshaft
« Reply #1 on: August 10, 2023, 04:12:23 PM »
Welcome aboard KemuelD2006
On which model(s) 77/78?
Offline KemuelD2006
    • Don’t have
Re: Camshaft
« Reply #2 on: August 10, 2023, 04:47:41 PM »
1978 honda 750k8
Online HondaMan
Re: Camshaft
« Reply #3 on: August 10, 2023, 05:04:29 PM »
Yes. There might be some slight changes in performance because the carbs of the K8 are set very lean for lowered emissions with a late-opening cam. If it ends up 'feeling' cold-blooded then there are 2 simple things you can do first to try to smooth that out:
1. Use higher-octane fuel (normally you should be running Regular gas now).
2. Turn the idle-mix screws outward 1/8 to 1/4 turn from normal setting (the K8 normally is 1.5 turns out).
If it still stumbles off idle after that (when warmed up) and you already have the idle-mix screws turned outward 1.75 turns, then you'll either have to live with that, or try to find some slightly richer pilot jets. The OEM version in the K8 carbs came 2 ways: if it was a California bike the idle jet will probably be #35 size (very lean) or if it is a Midwest or East Coast bike it will probably be #38 (technically a #37.5) size. Changing either one up to a #40 size jet will return the idle-mix airscrews to their working range again, and the final setting will come in around 1.5 to 2.0 turns, usually.
The K8 is/was the leanest-mix bike of the whole 750 SOHC4 series bikes, and it has a late-opening intake cam that opens the intake valves at 0 degrees TDC, and also opens the exhaust valve early at 175 degrees (i.e. 5 degrees before BDC) for better scavenging and lower emissions.
If the new cam comes from the 750F0/1/2/3 engines it will drop right in, but if it comes from any of the K0-K6 engines, then the above rules apply. These cams will also provide a bit more low-end torque, helpful for pulling away from stopsigns, etc.
Offline commander60
Re: Camshaft
« Reply #4 on: August 10, 2023, 05:41:31 PM »
I just put 40 pilots on my K7, that was way too lean. One turn out on the screws, runs perfect!
Offline KemuelD2006
    • Don’t have
Re: Camshaft
« Reply #5 on: August 17, 2023, 03:35:52 PM »
What does the r6 mean on the camshaft
Re: Camshaft
« Reply #6 on: August 17, 2023, 03:39:20 PM »
Its a casting number according to a lot of talk on here and does not identify year etc..
