Author Topic: To fix or not to fix, a short story by Broken Carbs  (Read 406 times)
Offline dazemc
« on: August 13, 2023, 01:23:34 PM »
Worth repairing? If so, how would you go about repairing them?
1971 CB500
Re: To fix or not to fix, a short story by Broken Carbs
« Reply #1 on: August 13, 2023, 01:32:11 PM »
As its only where the rubber from the air box seals it should be salvegeable using a cone of the correct diameter, or by replacing that carb body if you can get one, check the number type on a flange to determine what you need.
You could also replace the complete bank if you dont want to do the work.
They look like 500/550 would help if you told us exactly what they are
« Reply #2 on: August 13, 2023, 02:30:32 PM »
 I'd look for a full set of nice ones or at least a rebuildable set of parts carbs. A dented one may be tapped back out, but the broken flange is a deal killer for me.
Offline beemerbum
« Reply #3 on: August 13, 2023, 04:15:36 PM »
I wouldn't
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: August 13, 2023, 05:06:21 PM »
+1 to this.
Offline newday777
« Reply #5 on: August 14, 2023, 04:22:58 AM »
Beyond repairing....... somebody mangled them. Save them for parts.
Stu
My current rides
Prior bikes....
