Author Topic: What's Best?  (Read 356 times)
Offline Vintageguy
What's Best?
« on: August 14, 2023, 07:44:53 AM »
What do you think is the best thing to clean out caliper bore(s).
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: What's Best?
« Reply #1 on: August 14, 2023, 07:50:21 AM »
If they are not pitted, white or green scotch bright should work with brake cleaner I think. I can't remember what I used the last time I cleaned one. If they are pitted there is not much you can do except replace. I had to replace mine, they were very pitted.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Vintageguy
Re: What's Best?
« Reply #2 on: August 14, 2023, 11:17:19 AM »
Not sure on the pitting part. Hopefully rebuildable. Thanks for the reply.
Re: What's Best?
« Reply #3 on: August 14, 2023, 03:16:05 PM »
 I use a small brass wire wheel on a dremel tool to lightly clean the groove. Scotchbrite on the rest. I usually find the pits on the piston and not the bore.
Offline BenelliSEI
  • 1969 cb750
Re: What's Best?
« Reply #4 on: August 14, 2023, 03:27:01 PM »
+1 to above, but before using the wheel I use a hooked dental pick to really scratch out the crap that builds up behind the seal. Especially the corner you can’t see. The wire wheel will just polish that crust, it really needs to be scraped out thoroughly or the seal will be too tight on the piston and brakes will drag.
Offline WideAWAKE
Re: What's Best?
« Reply #5 on: August 14, 2023, 05:28:24 PM »
If it’s an early bike with an early original that’s pitted it can be sleeved and saved.
Runs about $100 bucks.
https://www.applehydraulicsonline.com/collections/sleeving
